Surroundbar 3000: buzzing from inputs #2 & #3
thep-a
thep-a Posts: 1
edited July 2012 in Troubleshooting
I've had a Surroundbar 3000 IHS for almost four months now.
Extremely satisfied with the sound!
Optical input connected to Panasonic Blu-Ray player.
Input#2 was connected to a DirecTV satellite box.
When I first got the unit, tried connecting an XM radio receiver.
When the receiver's wall wart was plugged in, though,
a buzzing or hissing noise would come through the SB 3000.
OK ... RFI from the wall wart ... stopped using the XM.
This week I added a TiVo to the AV system
& rewired all the connections.
Now, there's a buzz (or hum or hiss ... take your pick) from the SB3000
whenever input#2 and input#3 are selected.
Even when no audio cables are connected to the inputs!
Even when audio cables ARE connected & shorted to ground.
The noise varies with volume control: Turn up the volume
and the noise gets louder.
No noise when input#1 (optical) is selected.
Any ideas or suggestions?
TIA for y'all's help!
Post edited by thep-a on
  • The_Emard
    The_Emard Posts: 1
    edited July 2012
    I've got the exact same problem. So I thought I would use input 1 via Optical cable.... but although it sounds great, there seems to be some sound skipping problems. It looks like the sound is fading in when coming from silence so I miss sounds and dialogues sometimes.
