My Amp Keeps blowing a fuse...
13»
    heiney9 Posts: 25,445
    edited March 2011
    FTGV wrote: »
    Certainly but just because some make false claims doesn't mean that a push/ pull Class A amplifier is not technically possible.
    Probably better to drop it. We aren't going to agree 100% based on the verbiage and in the end it's not as important as the attention the issue is getting. I had my say......I'm moving on.
  • megasat16
    megasat16 Posts: 3,521
    edited March 2011
    FTGV wrote: »
    Your too nice.
    Thanks for the complement, Fred! :smile:
    I agree about the Push-Pull Class A. There are many Push-Pull Class A (real Class A without ever going into B) amps out there including that of NP.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    megasat16 wrote: »
    Yep there's been several examples (though mostly older designs)from the likes of Levinson,Bedini,Musical Fidelity,Krell ,Classe and Threshold.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited March 2011
    megasat16 wrote: »
    FTGV wrote: »
    Definitely not in line with my electronic training. I'm with H9 on this but what do I know (that training is soooo far away)...
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    TECHNOKID wrote: »
    Well something for you to ponder, the oft quoted Mr.Pass refers to his super sym. Push Pull XA.5 Series as "Pure Class A".Whereas the X.5 Series is refered to as high bias Class A/B.
  • zingo
    zingo Posts: 11,258
    edited March 2011
    zingo wrote: »
    I've had my eye on Red Wine Audio, Plinius, and Bryston among other; any feedback?
    Not to derail you guys :tongue:, but does anyone have opinions of any of the above amps as I have leads on all of them, but haven't heard them. Here are my thoughts:
    I 90% like the sound of my speakers with the Tripath amp I have now, and supposedly the Red Wine is Tripath at it best; especially since it's battery powered.
    Bryston has some of the lowest distortion and noise numbers in the industry, which obviously are a plus with sensitive horns. Plus, it is designed with a short signal path, low number of transistors, and minimum distortion starting from the first watt even though it is class A/B.
    Plinius uses a JFET input and supposedly sound like a class A amp, even though it is A/B.
  • TECHNOKID
    edited March 2011
    FTGV wrote: »
    Well the oft quoted Mr.Pass refers to his super sym. Push Pull XA.5 Series as "Pure Class A".Whereas the X.5 Series is refered to as high bias Class A/B.
    Well, how about Pure Marketting Tactics? :wink: To ny knowledge, while class A provided the best sound it was not an efficient way to do so. Class B was not a good performer SQ wise while Class C was better performer power wise but with very poor quality of sound (the worse of the 3). Class AB was created as a trade off providing for best combination of power performance and audio performance using push pull technology.
    An Alternative?
    Where it is not feasible (economically or otherwise) to use a Class-A amp in the tweeter frequency range, a modified Class-AB amp could be used. The modification needed is to increase the quiescent current (to perhaps 1 Amp or so) so that the amplifier operates as Class-A for any signal below about 8 Watts - assuming a well behaved 8 ohm load such as a tweeter. Such a modification to an existing amp is quite simple for an experienced electronics engineer or service person, but will almost certainly require that the heatsinks be upgraded to prevent the destruction of the output devices. It is also probable that additional capacitors will be needed for the power supply - and possibly a regulator or capacitance multiplier circuit, too. Without these, the hum level may become intrusive, which rather negates the whole purpose of the exercise. Some basic experimentation is required for anyone thinking along these lines.
    Modified AB operating as a class A is NOT in my opinion a true Class A.
    http://sound.westhost.com/class-a.htm
    DARE TO SOAR:
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    zingo wrote: »
    Yeah what are you thinkin?:tongue:
    No experience with Plinius or Red Wine but which Bryston model?I have a 3B ST and 2BLP and PP120.
    TECHNOKID wrote: »
    Rod Elliots site is always a great resourse of info but in that article he is in disagreement with you.
  • zingo
    zingo Posts: 11,258
    edited March 2011
  • TECHNOKID
    edited March 2011
    I like the Plinius as gives the best of both world. Actually I believe the Plinius doesn't act as a class A but rather can be selected in either A or AB, am I correct? Nice review on them anyway... http://www.soundstage.com/revequip/plinius_sa102.htm
    DARE TO SOAR:
  • FTGV
    FTGV Posts: 3,650
    edited March 2011
    The B60 has a very nice pre using discrete Class A opamps.The amp section is essentially the same as in my 2BLP though mine has the older (non SST)output devices.I would characterise my 2B as reasonably neutral but with sweet top end and surprisingly dynamic and punchy bass for a small amp.
  • megasat16
    edited March 2011
    TECHNOKID wrote: »
    Are you saying your book has only one chapter and it ended? Or are you not going into chapter 2 and so on?
    FTGV wrote: »
    Great Point you made there! A lot of these High End amps are now called called Pure Class A even though they are Push-Pull.
    TECHNOKID wrote: »
    Refer to chapter 2, Page 1. Read Differences between Class A topology and why Push-Pull is also Real Class A. (This advise is not for Brock, his book has only one chapter coz additional chapters are still written by Papa Pass at this time...:biggrin: :tongue:)
    Sorry Jake! I couldn't help it. Last derail though, I promise! :redface:
  • vivid2012
    vivid2012 Posts: 6
    edited March 2011
    TECHNOKID wrote: »
    looks great!!
  • Face
    Face Posts: 14,340
    edited March 2011
    zingo wrote: »
    Shhhh...we're talking about Class A. :biggrin:
    FYI, your Plinius link isn't working.
  • TECHNOKID
    edited March 2011
    zingo wrote: »
    I am not familiar with the red wine audio amps but it looks pretty impressive. I like the idea of the class A tube stage triod. You can't go wrong with Byston either. As Face mentioned, your link for the plinius doesn't work would be nice to see it.
    DARE TO SOAR:
  • zingo
    zingo Posts: 11,258
    edited March 2011
    I forgot that the Red Wine has a 6922 class A input. :smile:
    It appears that the Plinius website is not working at the moment. I will re-link it when it is.
  • zingo
    zingo Posts: 11,258
    edited March 2011
    I think may take a crack at the Red Wine Audio Signature 30.2 LFP-V Edition Stereo Integrated Amplifier. It may be a $3K Tripath amp, but I've been able to find nothing bad about it and Vinnie thinks it will be worlds above my current Tripath based King-Rex T20U+PSU which I like a lot. Battery powered amps have always interested me since I've owned noise sensitive horns, and his smart charging system with new Lithium Iron Phosphate batteries seems to be the best available.
    index.php?action=gallery;sa=view;id=15749
    I guess that means I need to put my Jantzen Audio custom Shuguang Treasure S300MK integrated amp up for sale...
    edited March 2011
    zingo wrote: »
    Sorry but I think it;s a mistake to sell a very nice 300B tube amp and replace it with a SS amp for use with horns.
    Let us know your reaction.
  • zingo
    zingo Posts: 11,258
    edited March 2011
    I enjoy my Tripath amp now, and in all the reviews I've read, Vinnie builds the best Tripath that competes against SE tubes and SS class A. That being said, I will be able to use the amp in my system before a purchase decision needs to be reached, so I will let me ears decide and do an A/B with this amp, a cheaper Tripath, and the 300B.
  • megasat16
    edited April 2011
    megasat16 wrote: »
    It's not Quasi Class A that I am talking about here. It could be Class A SE or Class A Push-pull but they are real Class A. There are lots of older ones from the 70s, 80s, 90s, and early 2000s you can buy under 2K.
    Jake,
    This is what I talked about before. This one is from Canada so shipping would be a killer but it's an idea for the Class A Integrated.
    No affil to the seller.
    http://cgi.ebay.com/LUXMAN-L-550-STEREO-INTEGRATED-AMP-PURE-CLASS-READ-/140535334820?pt=LH_DefaultDomain_2&hash=item20b88f07a4
