Pic of bad crossover???
BrettSelinsky
This is out of an R50 that is getting very low output to the tweeter. Can barely hear it. Tried the good one out of my other speaker same thing.
The pic shows the capacitor (from the crossover)?? (if thats actually what its called?). The top is bulging out and there is a little bit of insulation pushed out also. I dont see or smell anything else unuasual.
Is this likely my problem?? Need new crossover?
Thanks for the input!
Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub
Post edited by BrettSelinsky on
Or a new Cap, which looks bad too me.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
That capacitor has gone bad an needs to be replaced. How are your skills with a soldering iron?
Whats a soldering iron. JK Im willing to try it though. What harm could i do? Im waiting on a response from Polk to see how much a new crossover is? I havnt got a clue to what that will cost?Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
Yeah, it's a bad cap. A crossover will cost a whole lot more than an electrolytic cap.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
How do I go about getting a new electrolytic cap. Would the part# be marked on it. How would I get the old one off? Just melt the existing solder off and pull it out? Sounds like a fun project since I just got a quintuple bypass and cant do to much.
ThanksBrett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
Usually I use a vacuum solder removal tool. The value for the cap will be marked on it. It will look something like "12 uf 250V" or something like that.Turntable: Empire 208
Arm: Rega 300
While you are there replace it with a Poly cap. This will need to be done to both XO's. The performance will increase.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
x2 what he said ^^^- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
When you say both crossovers do you mean. The same cap on both crossovers or both caps on the (1) crossover.
is the poly cap a different style, make, or what.
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
A poly cap is a different type of cap. The one that is buldging is an electrolytic. Replace the caps on both boards.
Ben -
Thanks so much! Here I go. Just removing the old to get the new. What about all this silicone looking stuff on th top of the board? Anything special to do with that? Dont laugh but does Radio Shack have these poly caps? This board is great. Giving me things to play with while I recoop from open heart.Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
BrettSelinsky wrote: »Thanks so much! Here I go. Just removing the old to get the new. What about all this silicone looking stuff on th top of the board? Anything special to do with that? Dont laugh but does Radio Shack have these poly caps? This board is great. Giving me things to play with while I recoop from open heart.
That "silicone" actually is hot glue, they use it to hold components to avoid vibrations etc. make sure the cap is the same as the one you are replacing, for example: if the old cap is 4.4uf and you do not find the same value you can go for the next closest match like 4.6uf, 4.8uf, make sure the voltage is the same or higher than the old one...you do not have to look for polarity since these crossover caps are non-polarized caps.Make it simple...Make it better! -
Thanks Again! Its out.
Just in case anyone else needs a cap for an R50 tweet side.
Y . C
12uF50v
+85 degrees Celcius
NP (non-polorized?)Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
BrettSelinsky wrote: »Thanks Again! Its out.
Just in case anyone else needs a cap.
Y . C
12uF50v
+85 degrees Celcius
NP (non-polorized?)
yes! NP=Non-polarized. you can use better caps than those cheap electrolytic caps, you can use like polypropylene, mylar etc from Parts express.Make it simple...Make it better! -
The closest I can find is a 22uf 50v. Should I go less on the uf or higher. Does this change the sound? The caps I removed are 12uf.Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
BrettSelinsky wrote: »The closest I can find is a 22uf 50v. Should I go less on the uf or higher. Does this change the sound? The caps I removed are 12uf.
Just visit www.partsexpress.com and type 12uf in the search bar. Snag a pair of Dayton film capacitors.- Computer Rig -
- Main Rig -
Bought cheap electrolytic caps and everything works as it should. Thanks so much for the help. I'm placing an order tonight for the good ones. I couldnt wait and it was only $2 bucks for the cheapos. You guys saved me a lot of money even with buying the cheap for now. And, it gave me something to do and some practice soldering during my recovery(by the way Im only 41,5'10" and 185#) so be aware of shortness of breath or chest pains(even minor as mine were) and get to the ER ASAP. Im assuming I saved alot for the crossover but Polk wont get back to me. They are usually great.
Thanks again!!!! I will post when I do the upgrade!!!Brett Selinsky
Denon 3805
Denon DVD/CD
Crown ProAmp
JVC VHS
RTi70's Front
CSi5 Center
R50's Rear
DefTech Sub -
Good luck with your recovery. I had triple bypass in 2002 and I was 45 at the time. Keep exercising and watch out for the extreme hot and cold temps. I was back to work 8 weeks after my surgery. Hang in there and keep us posted.
