MW-6501 Mid Bass Driver
Texas42
Texas42 Posts: 410
edited February 2011 in Troubleshooting
Are these still available new or are there suitable substitutes for this driver (from Polk or OEM)? Thanks for any info. Driver is for RTA-12s.
Post edited by Texas42 on
    F1nut Posts: 52,151
    Customer Service & Tech Support:
    1-800-377-POLK (7655)
    9AM-5:30PM EST Mon-Fri
  • Texas42
    Texas42 Posts: 410
    I have a friend who has several extra MW 6503 midbass drivers. Would these work in place of the 6501? They look identical but not sure of the impedance matching.
    F1nut Posts: 52,151
    Not really, as you suspect they have specs.
  • Texas42
    Texas42 Posts: 410
    I think I found my answer here:
    http://www.polkaudio.com/forums/showthread.php?t=10446&highlight=6501+6503
    Looks like the 6501 was the replacement for the 6503 so either should work.
    F1nut Posts: 52,151
    No, that's not right. The 6501 came first and while using a 6503 in its place may be deemed "useable" one is not the replacement for the other.
