How big should my sub be??
K-daugh
K-daugh Posts: 467
I have a 16' x 18' room with 8' ceilings ...carpeted floors.... and solid core entry door...two solidcore closet doors... with an 7'6" x 5' window on one wall...also i have 1/2" soundboard underneath 1/2" sheetrock on the walls and r-13 insulation in all 4 walls and r-30 insulation in the ceiling.....so my point being the room is tight .....now what size sub or subs should i be running for 95% ht alongside my modest set-up....
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
  • ben62670
    ben62670 Posts: 15,969
    edited February 2011
    A big solid sub. This is a house correct.
    Ben
  • danger boy
    danger boy Posts: 15,722
    Huge!
    PolkFest 2012, who's going>?
  • ben62670
    Save some coin and screw this one together.
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-764
    Ben
  • 20hz
    20hz Posts: 636
    K-daugh wrote: »
    Of coarse big because you can always turn it down but you cant turn it up if you got all the way up allready .
    ALSO you get a few free decibles if its in the cornor !
    I suggest hear a few differant ones and go towards what you like .
  • Polkie2009
    Polkie2009 Posts: 3,834
    Doesn't somebody here say something like ,"you'll rarely hear anyone say I wish I had gotten less Sub".
  • K-daugh
    K-daugh Posts: 467
    Currently got a mirage bps150i and it does ok most of the time but when I'm watching blu rays and the big explosion scenes happen it just doesn't sound realistic.....even muddy at times on the really low stuff ....is that because it isn't enough sub ??
    Custom Jumpers
  • Erik Tracy
    Erik Tracy Posts: 4,673
    I'd ask your wife.....:biggrin:
  • K-daugh
    K-daugh Posts: 467
    Oh my wife hates the one I have .....but I'm more concerned about the realness of the bass I want it to sound like an explosion when I'm watching 2012 and not just an extremely loud **** !!!!!
    Custom Jumpers
  • ken brydson
    ken brydson Posts: 9,059
    Get the biggest baddest sub you can afford. Figure out your max budget and add $500. You'll thank me later....:biggrin:
  • Erik Tracy
    What he said.
    It does come down to what your budget can afford....so how much can you scrounge up from the couch cushions? :biggrin:
  • codyc1ark
    codyc1ark Posts: 2,539
    This is how I did it... Tell the fiancee that I'm going to spend X on a new sub, then double X, thats how much sub you need to spend. See what she'll greenlight (in my case around 300), so now i'm in the $600.00 range...
  • K-daugh
    K-daugh Posts: 467
    Nm I just spent 410 on an adcom 7605 ......next purchase will definately be a sub though .....my budget is most likely gonna be around 4-500 dollars so I should add 500 to that puts me at about 850-1000 lol I gotta a lot of pan handling to do .....I may be able to get a couple hundred for the mirage ....I dunno
    Custom Jumpers
  • Erik Tracy
    K-daugh wrote: »
    You'll need to factor in how much shipping will cost - cuz the bigger the sub, the bigger the shipping bill will be.
    You may want to consider used...keep an eye over on audiogon.com for a used deal.
    Or watch for deals where you get shipping free (could happen on bigger subs, but not likely).
    Enjoy the problem - consider it a quest for the best! :biggrin:
  • nguyendot
    nguyendot Posts: 3,594
    http://www.eminent-tech.com/RWbrochure.htm
    Get this... and it won't even use up floor space!
    Main Surround -
  • quadzilla
    quadzilla Posts: 1,543
    I thought that was a joke at first, but they're really serious. They're statements aren't exactly accurate though. The Exodus Maelstrom 21, for example, is flat down to 10 Hz at a higher output in an infinite baffle configuration. Finding an amp that will output anything at 1 Hz will be tricky too. But still, I'd be interested in "hearing" one at least for kicks and giggles. Downside, especially around here, would be having a fan blowing in and out of my attic during the summer. Either way, it's still a bit of genius. Mad genius, but genius none the less.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Erik Tracy
    quadzilla wrote: »
    So, for 'professional installation' in either roof or basement....is there additional duct work to vent the sound into the listening area?
    I saw the fan/woofer rotating in the ad - but where does it go?
  • nguyendot
    you'd have to loop the air in and out of the theater room or you'll be drawing outside air into your living space.
    Main Surround -
  • quadzilla
    nguyendot wrote: »
    That's not how they show it configured. They specifically say it has to use the attic to acheive an infinite baffle configuration. And in an infinite baffle configuration, I'd take a Maelstrom 21" @ flat to 10 hz and only 4-5 db down at 5 Hz, depending on room.
    Arm: Rega 300
  • Erik Tracy
    quadzilla wrote: »
    Ok, so where does the fan blow and where does it exit?
  • rooftop59
    rooftop59 Posts: 8,120
    back to the topic at hand...that mirage really is a pretty killer sub UNLESS you want to pressurize the room. It is a GREAT 2 channel sub, and solid for the vast majority of ht. I loved mine, actually sold it on audiogon for $300, and I think that it well worth that. So if its in good condition I think that you can get at least 200 for it, and up to 300 if its in really good shape and you find the right buyer. So I think that you can safely add that to the budget.
    Game Room 5.1.4:
    Bedroom 2.1
  • newrival
    newrival Posts: 2,016
    I second Ben's suggestion on the Titanic. I've got a pair of em myself :D
    I'm sure there are better out there for more money, but these have been the best I've experienced in my home <$1000. And at ~$750 on the current sale, I think that's a killer deal.
  • quadzilla
    Erik Tracy wrote: »
    It blows into and out of the room, since the blades reverse their pitch.
    Arm: Rega 300
  • Erik Tracy
    quadzilla wrote: »
    Hmm...sounds expensive to do the install and put ducting from the attic (or basement) to where the HT room is. How would you even do that for a 2-story home with the HT room on the bottom floor - run ducting outside the house?
  • Slyder01
    Slyder01 Posts: 115
    keep the sub you have and add another. More is better in my opinion. The three i have fill the room quite nicely.. LOL,, nicely, now what kind of word is that when it comes right down to punch you in the chest,head,stomach BASS! Oh yea baby!
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    Polk fxia6 Rear Surround
    Paradigm Micro Rear Back
    Onkyo bookshelf Front Presence (for now)
    PSW 450 Front Sub
    DSW MicroPro 4000 Front Sub
    DSW MicroPro 2000 Rear Sub
    Samsung c6300 60 inch LED
    Sony BDPs370
    Room Size 15x30
    EndersShadow Posts: 17,741
    I would suggest dual SVS PB-12NSD DSP's, or dual PB12+ DSP's. Either one of those would fit the bill quite nicely. Another option would be dual Epik Empires as well.
  • TNRabbit
    TNRabbit Posts: 2,168
    I think the general rule of thumb is the sub must be at least the size of your refrigerator~
    you could get a LOT of Epik for not muchh $$$
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • Slyder01
    Slyder01 Posts: 115
    Yamaha rx-a2000 AVR
    Polk csi5 Center
    Polk rt16 Main
    PSW 450 Front Sub
    Sony BDPs370
    Room Size 15x30
  • K-daugh
    K-daugh Posts: 467
    rooftop59 wrote: »
    ok so say i wanna keep the sub i have....which i do... could i get away with a 10 ....or what?? ....what would compliment the mirage nicely ?? say there is a 500 dollar budget ??should i look for another 150i ??
    Custom Jumpers
  • Ern Dog
    Ern Dog Posts: 2,237
    For 95% HT you can't beat SVS for the money. I would recommend you buy used to stretch your dollar.
  • JimAckley
    JimAckley Posts: 1,138
    Ern Dog wrote: »
    For something prefabbed sure, but there are some DIY solutions out there that can.
    edit: just saw your budget... no clue how I missed it :tongue: Personally, I'd go with a DIY kit like the Dayton kit mentioned earlier. It's slightly over your budget, but you can't beat the bang-for-your-buck of any DIY kit. Plus you want something that's a one-and-done solution, not something that will hold you over for a while until you can afford something else.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
