Using a center ( cs10/20 ) as fronts
Hi, new to the forum, anybody has any opinions (pros/cons) on using a pair of cs10 or cs20 as mains for the front?
The main reason I am considering it is the shape, the tsi200 are to big (depth). Any input would be helpful.
Post edited by fyrn on
It'd work..but I don't know why you'd want to.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
What is the max depth you can work with? You could have better options based on that number.
The main reason for doing this is space, I have only about 10.5in deep, but I have lots of horizontal space to use. My main concern is sound. Is the speaker "tuned" differently because it is a center channel?
http://www.polkaudio.com/homeaudio/tsi/index.php?s=tsi100
These would fit.Dan
Some S6's or 8's would fit and make for some nice fronts.
