TV Riser 2. Anybody ever use one?
jbooker82
jbooker82 Posts: 1,627
edited March 2011 in The Clubhouse
I was wondering if anybody has used a Tv Riser 2 by Wood Technology. It is a shelf that you set on top of your entertainment center or tv stand. It has a 23x8x17 cubby hole that you can put a center channel in. It wont fit a 6A center channel but a 4A should fit fine.
What do you think?
My tv stand now is only 19 inches tall so the tv could probably be ok lifted up another 8 inches. The bottom of the Tv screen is around 24 inches off the ground. The tv stand just has a single shelf and 2 drawers. I had to cut 1 inch off the back side to be able to slide my onkyo 808 in.
Here is an amazon link and pic
http://www.amazon.com/Wood-Technology-TV-Riser-Two/dp/B0043WG9H4/ref=sr_1_2?ie=UTF8&qid=1297680792&sr=8-2
Not my pics. They were on amazon too.
AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II
Post edited by jbooker82 on
  • jbooker82
    edited February 2011
    Here is pics of my current setup.
    There is about an inch clearance between the AVR and the drawer above it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Earthy
    Earthy Posts: 488
    I was faced with a similar dilemma. I just hung my set on the wall with a $30 bracket, and poof... instant center shelf.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • TNRabbit
    TNRabbit Posts: 2,168
    You can make one for half the amazon price.
    Also, there are some great stands now that have a support up the back to mount your tv above everything....WalMart has some really decent ones for less than $200.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • jbooker82
    I cant hang a tv on the wall. I just rent my appartment and wouldn't want to put large holes in the sheetrock / drywall.
    I might look at the wal mart tv stand.
    I would be able to make one if I was closer to my inlaws or my parients. I dont have the tools to do it here at my home. Finding hard wood board 1in thick by 17 inches wide is kind of difficult. I might check with a lowes, and home depot. Maybe they sell hard wood boards that have alread been joined / glued together for that wide width. It wouldn't have to be a single board wide.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Earthy
    Earthy Posts: 488
    Lowes has 1"thick 11.5" x 4ft oak stair treads for around $20. Not as deep as your looking for, but very solid. You could probably get them to make the cuts you need.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • TNRabbit
    My son has that exact same tv stand (looks like a coffee table to me!):
    Lowe's item Earthy described:
    1 x 12 x 4 Red Oak Board
    * Item #: 1066
    * Model #: 08382
    $24.72
    A few screws & some black paint & you're there!
    TNRabbit
    Sunfire TG-IV
    Nice set up. But that Onkyo needs more breathing room...IMO. Those babies get HOT. Very hot! I have a foot and a half of space over mine.
    cnh
  • ViperZ
    ViperZ Posts: 2,046
    cnh wrote: »
    cnh
    I have a low-profile dual-fan, which runs off a small ac converter (running these fans at 4.5V nowdays to reduce noise). Onk loves those fans and runs much cooler :)
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • jbooker82
    I havent noticed it getting to hot. If it does I can take the bottom out of the drawer above it. That would give it quite a bit more room.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • KASR
    KASR Posts: 450
    TNRabbit wrote: »
    * Item #: 1066
    * Model #: 08382
    $24.72
    I gotta go with Rabbit on this one - DIY and take pride in your masterpiece and spend the rest of the money you saved on beer! :D
  • nguyendot
    nguyendot Posts: 3,594
    Mount it to the wall.. You can just mud the holes when you move out.
    Main Surround -
  • Earthy
    Earthy Posts: 488
    nguyendot wrote: »
    I agree with that. You will just have four 1/4" holes to fill with mud.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
    EndersShadow Posts: 17,725
  • brettw22
    brettw22 Posts: 7,623
    I wouldn't ever put something like a TV on a shelf that has no cross support.
    If the shelf in the OP had a connection between the two vertical 'legs' then I'd be fine, but if that thing so much as tilted too much, goodbye TV and whatever else below it.
    I need to get something similar to raise my TV to accomodate my surroundbar, but it's got to have some strength.
    brettw22 wrote: »
    I have seen folks mount the RTI centers on the wall mount shelf with no problems.
    Heck he's got space above the TV. 2 L brackets and a cheap shelf later and hes golden.
    If he needs to tilt the speaker get some Auralex MOPAD Monitor Isolation Pads and call it a day
  • brettw22
    So when I made the point, I specifically said that my comments were geared towards having a TV (aka something that's not light as a feather) on a support that has no cross support.
    Last time I checked, a center channel doesn't weigh what a TV does.........
    brettw22 wrote: »
    My apologies. I mis-read/skimmed your post and obviously missed the intent (which I now see). :redface:
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    You don't have to drill large holes to mount it on the wall.
    Just get two solid pieces of wood (I used wood flooring), then use 4 long wood screws and go into the studs. Now you have a solid anchor, so you can then mount into the wood. If your mount happens to line up with the studs, you can do that too. When its time to leave, you've got four holes slightly bigger than those created to hang pictures
  • newrival
    newrival Posts: 2,016
    brettw22 wrote: »
    My center channel weighs 4lbs more than my tv does ;)
  • brettw22
    newrival wrote: »
    Then you have a **** TV......:biggrin:
  • mantis
    mantis Posts: 17,568
    Here is the solution to your problem
    http://www.salamanderdesigns.com/whatsnew/index.jsp
    Do not use that crappy TV stand. This will give you a real gear stand with a center channel shelf and you can get the one that suits your gear now and maybe get one that has some room for gear in the future.
    If you check out the Synergy line , they have build your own cabinets that can grow into more as they are modular.
    Dan
  • jbooker82
    I went a head and ordered the TV Riser. If it was my place and perminant I would just mount the tv on the wall. I am probably to nice of a tenant.
    Wall mounted tv with that pro audio rack would be pretty slick.
    I think my tv's spec sheet says it weighs 89 lbs.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Earthy
    Earthy Posts: 488
    Let us know what you think of it once it comes. Pictures too!
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • jbooker82
    I will deffinatly post up some pics when I get it.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • DaveHo
    DaveHo Posts: 3,583
    I built my own once. I spent a lot of time & money since my display at the time was a big old CRT weighing nearly 200lbs. I was proud of my creation, it looked great. However, that's where the happiness ended. Made the center sound like it was in a cave. Vocals sounded tubby. It was a big disappointment. Since I had put so much effort into it, I used it for awhile, but ultimately ended up tossing it in favor of a dedicated stand in front of the display. Hope your experience is better.
    -Dave
  • jbooker82
    I can see where that can happen. I plan on having the grill sticking out a little instead of having the speaker pushed clear back in, under the tv. I just didn't want the look of the speaker sitting in front of the tv.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • jbooker82
    edited March 2011
    Here is my pics and review. It is in the DIY
    http://www.polkaudio.com/forums/showthread.php?p=1545386#post1545386
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • jbooker82
    edited March 2011
    It works great and sound the same as having it just sitting in front of the tv. I dont have it fully recessed. The grill sticks out of the cubby hole a little. That way it isnt sunk clear back in.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
