PSW111 vibrating
stoner60
About a year ago my PSW111 needed a new back panel unit because of fuses blowing on the original. Sorry I'm not sure what the part is called.
Anyway, recently the sub has started to make a vibrating sound while watching movies with really deep low end sounds.
Anyone have any idea what causes this or if it can be fixed?
The unit is approximately 2 years old.
Dean
Dean
Post edited by stoner60 on
It may be reaching it's limit, often referred to a bottoming out. First thing you should do is recalibrate everything. Gain on the sub should be at about 50%.
Excuse my ignorance or lack of audio knowledge but what is the "gain" and how would I adjust it.
Also, thanks for the response.
Gain in this discussion refers to the subwoofer amplifier volume dial position.
The recommended starting position is at 50%, generally meaning that the subwoofer amplifer dial white pointer is pointing straight up (12 o'clock analog hour hand position). -
OK......I don't feel too dumb for asking that. But hey at least I'm not trying to make a sub out of a mtotr oil box!!
I did recalibrate everything and set the volume knob at 12:00 and it is much better!! Thanks for the info and for not flaming me.
