Help Please!
Gonzonator
Gonzonator Posts: 18
edited February 2011 in Troubleshooting
Hello everyone, I was hoping someone could point me in the right direction. I have a center channel speaker, it has two 5 inch mid range/bass drivers and a tweeter. It seems that one of the drivers is producing lower volume than the other. I thought the driver was shot, but I switched them and the same side still sounds lower. Does anyone know what could be causing this? Thanks
Post edited by Gonzonator on
    F1nut Posts: 52,151
    Some center channels are designed that way. What brand and model do you have?
  • Gonzonator
    It is a B&W Dm600 IFS. I never knew that some center channels were designed like that. Is their a way to tell from the specs if it is supposed to perform this way? It is a older speaker that I bought second hand, I thought for sure something is wrong, but hope not. Thanks for any help
    F1nut Posts: 52,151
    I know nothing about that one, contact B&W.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    It's a cascaded crossover, it's fine. As Jesse mentioned, a lot of center channel speakers are designed that way.
  • ohskigod
    ohskigod Posts: 6,505
    yep, Polk LSiC is the same way. if you check the specs, sometimes you will see 2 different crossover frequencies. One woofer is handling bass up to midrange, the other just does low frequencies with a lower cutoff.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Gonzonator
    Hey thanks for your help. I did contact B&W and this is what they said: Hello and thank you for your email. The DM600IFS is considered a 2 ½ way speaker. This means that all three drivers will output different frequency ranges. This is normal operation. I'm still not sure I like the way it sounds, I had a Polk CS1 and a Boston Acoustic center speaker and they seemed to perform better. The only reason I switched was I wanted my front three to match, anyway at least the B&W is in good shape, thanks again.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    RuSsMaN wrote: »
    Then IMO this is piss poor desiging :eek:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
