12V Trigger
bdtae5656
Im looking for a remote trigger that will power up my Xpa-5, i've been doing a lot of reading on wall-warts and want to make sure that i get the right one. Also any help on triggering my Rotel?
TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Post edited by bdtae5656 on
Are you using the 120v switched outlet to turn the wall wart on and off? Does the Rotel have a switched outlet?
In the above scenario any small 12v wall wart will work, the trigger hardly flows any current. The key is testing for polarity (+ and -) of the 12v output to be correct for the amp trigger input.Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU. -
I havent bought anything yet, i wanted to get some feedback before I bought anything. The Rotel doesnt have a switch it.TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
I use a radioshack wall wart my panamax had only a 117 and my other stuff wanted that 12v plug , setup works fine 10 years now ..
I fire up amps dvd xover all kinds of stuff that panamax ?1500? was well worth the $$ and when the releys wore out panamax sent me a brand new unit for $25 , its a great company ! -
I totally forgot that i had a trigger on my Panamax, what will i need to plug the amp up to the Panamax with and im assuming i'll now need to plug the power source of the amp to the Panamax??TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Blueray: Opp 93
certain panamax's does not have a 117 v trigger it only has a 12v trigger in that case you will need a wall wort plugged into rotel (does it have a switched outlet) .
I had a older panamax it was like 2" tall, it had a place where the 117v triger plug plugs in from the AVR but my newer m5100didnt so I had to purchase a 12v wallwort and the panamax had a ?1/4"? female plug for that , actually the replacement for the old one had no trigger the 5100 did (but needed a wallwort ) . I GREATELY recomend calling panamax !
