Delayed sound
FJD
Sometimes the Surroundbar 3000 output is delayed, causing the picture and sound to be out of synch. Any ideas in what causes this and how to fix it?
Post edited by FJD on
this is a common problem with receivers, cable, and certain audio outputs on tv's. Many times its due to the processing of the digital picture by the tv and the audio going out before the video signal is processed and up on the screen. there are devices that can adjust the delay but theyre a couple hundred bucks.design is where science and art break even.
I had issues with a small delay difference between using analog RCAs and a digital optical cable. I had my Kenwood unit feeding a unit in another room via optical cable. The optical cable always seemed to have a small delay to it which drove me nuts. I finally was just too frustrated by it and got a long analog cable to replace it. Not sure if this will help, but I thought I'd throw out the insight.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
