Cloth for waxing?
audiobliss
audiobliss Posts: 12,518
edited February 2011 in The Clubhouse
I cleaned up my car yesterday. Spent about four hours between washing it, drying it off, vacuuming it out, wiping down the dash and center console, waxing it, and cleaning the windows. I've always used a paste wax and done it by hand, and I have no desire to change that. However, I was reminded of something yesterday that always bugs me. After I let the wax set for a few minutes to haze and then start to buff it off, the wax grabs my microfiber cloth that I have folded up into fourths, making it hard to buff it off and unfolding it at the same time. I find that incredibly annoying. If it weren't for that, it's really a pleasant experience that I enjoy.
Could this be due to the type of towel I'm using? Would a different towel be better? What about a nicer microfiber? These were pretty cheap at walmart if I remember correctly.
Just for reference I've been using Turtle Wax Ice paste for the last while now.
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • Jstas
    Jstas Posts: 14,849
    edited January 2011
    I've always used just old but cleaned cotton T-shirts or other cotton rags. Never saw the sense in microfiber when it doesn't really get you much.
    Now I use a random orbit buffer. I apply the wax by hand with a hand sponge and then it gets taken off with a terry cloth pad and buffed out with a foam buffing pad.
    The 4 hours of waxing time gets old after a while. The buffer brings it down to about an hour to an hour and a half.
    Expert Moron Extraordinaire
  • exalted512
    exalted512 Posts: 10,735
    edited January 2011
    treitz3 Posts: 19,289
    edited January 2011
    From the link above....
    "They work on this unique principal: Within every pad, are a series of metal spikes. When the pad is worn out, the foam breaks down, then the metal spines penetrate the cloth, and leave a visual indication on your vehicle, so you know when it's time to replace the pad!"
    :eek:
    They may want to reword that a tad....
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2011
    I use both botton Tshirts and Micofibers. I understand your pain, that wax gives you a good workout for sure. Zaino is alot easier to work with so I've made the switch.
  • Jstas
    Jstas Posts: 14,849
    edited January 2011
    treitz3 wrote: »
    :eek:
    Ummm...you do realize that that site is fake and satirical, right?
    I'm hoping Cody does too.
    edited January 2011
    Um......yeah, *clears throat* Of course...
  • thsmith
    thsmith Posts: 6,082
    edited January 2011
    ALWAYS use a towel that says made in USA. Only way to make sure it is 100% cotten.
    Purist will use only white.
    I find it best to knock the heavy stuff off first and then come back with a clean towel to get the final layer of wax off.
    Here is a great link.
    http://www.waxdepot.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=WD&Category_Code=K
  • exalted512
    edited January 2011
    Jstas wrote: »
    No buddy, the o-pipe is real!
    http://kalecoauto.com/index.php?main_page=product_info&cPath=1&products_id=2
    -Cody
  • Earthy
    Earthy Posts: 488
    edited January 2011
    That KaleCo site is a hoot. Great pricing on blinker fluid.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • audiobliss
    edited January 2011
    Thanks for the input, folks. Appreciate it. I think I'll cut up an old cotton tshirt for next time. Front side for removing hazed wax, then the back half for buffing it smooth.
    I've also been looking online for the Original California Water Blade to help dry it off, as a friend has one and it works wonderfully! I can't seem to find the original one with the t-blade. Looks like this new one with a supposed 'v-edge' is what's currently available. Might grab that from amazon here soon.
    exalted512 wrote: »
    I had forgotten all about that site! Hilarious stuff! You think they really sell the t-shirts they have on their site? There's one on there a friend would LOVE to have.
    thsmith wrote: »
    Thanks for the info and the link. Assuming it's a reputable site, I definitely learned quite a bit. I've never used a true 'polish' before. Will have to look at them at Walmart next time I'm there. I have a clay bar kit that I used, only once, and I'm pretty sure I didn't have enough motivation to do the whole car. I have used (and did just yesterday) some Turtle Wax Rubbing Compound on really stubborn or rough spots, or where paint from something else has gotten rubbed onto my car.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • blueboxer
    blueboxer Posts: 621
    edited January 2011
    I agree on the 100% cotton made in the USA or a microfiber towel. Turtle Wax paste is a pain to remove, the only thing harder is maybe Collinite, which is a great wax. Zymbol, Menzerna FMJ, or P21S are much easier to apply, remove, and leave a better finish IMO. If you want to stick with Turtle Wax, you can use a detail spray as you remove it. Just mist the paint surface with the wax still on it and it will decrease the amount of elbow grease required.
    VR3 Posts: 28,822
    edited January 2011
    Get zaino and you won't have that problem
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2011
    I've always used soft cotten baby receiving blankets and brand new cotton diapers. For drying after wash and removing wax.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • Sherardp
    edited January 2011
    Some of the best wax out there. Zymbol is supposed to be good also. I'm a big fan of Zaino, the stuff does magic.
  • bsoko2
    bsoko2 Posts: 1,449
    edited January 2011
    Used cotton baby diapers (washed first of course).
  • amulford
    amulford Posts: 5,020
    edited January 2011
    I use the kid up the street...
    billbillw Posts: 6,910
    edited January 2011
    Switch to Meguires or one of the 3M products if you want an easier time applying/removing. Turtle Wax has always been hard work to remove. I don't think it matters what type of towel/cloth you use. Spray will help though.
    I think car detailing was a common activity this weekend around the South (since it was in the 70's both days). My shoulders are sore today from doing the same thing on my car Saturday and Sunday. Wash, clay bar, and a coat of 3M Performance Finish.
    However, I need to get rid of some swirl marks and other paint defects. My new car is black and it really shows the flaws badly. So, I'm with Jstas and I will be buying a dual action orbital polisher to help me out. Probably the Porter Cable 7424XP. These 40 year old shoulders just can't do the heavy polishing.
    Oh, and here is my new ride:
    No more Mazdaspeed. Wife couldn't stand the car, and frankly, I was getting tired of it as well. To loud, to rough, too much torque steer. The dealer gave me an outstanding trade-in price so it was worth it. Its a one previous owner '07 C350 Sport with AMG package.
    For rig details, see my profile. Nothing here anymore...
  • quadzilla
    quadzilla Posts: 1,543
    edited January 2011
    oh thank god... I thought this was going to be a thread about hair removal when I saw the title :p
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • mantis
    mantis Posts: 17,208
    edited January 2011
    Fongolio wrote: »
    I have also used these , they work very good. I made the switch to high quality Micro Fiber and have not looked back. I really like the way Microfiber works as I can use a signal Towel and "wax off" my entire truck with ease.
    I use to be a Detailer way back in the day and have used many different kinds of wax. For home and professional use , these are the waxes that work best and are easy to remove.
    Mothers Gold Pure Caranuba max with no cleaners. Excellent wax , stays on for weeks and is very easy to remove. This is a fantastic "home" wax.
    http://www.mothers.com/02_products/05550-05750.html
    As a Professional I used 3M products for compounding , polishing and waxing. There products work very good and give a super clean finish. This wax was my favorite overall.
    http://www.autogeek.net/3mpershowcar.html
    One thing you gotta keep in mind , if your finish isn't perfect , wax tends to stick to it more making it harder to remove. Prep work makes all the difference in the world , removing contaminates before waxing. I suggest taking your car or truck to a professional detailer and let him do a full outside detail. This will remove all tar and road scum , compound off any oxidized paint and give you a very nice surface to work with. Once you have this glass type surface , waxing becomes very easy.
    Also wax often , it makes a huge difference. During the spring summer and fall , I usually wax 5 to 6 times. Every few weeks I put on a fresh coat. It takes usually 15 to 20 minutes tops to do the entire truck. I own a Nissan Pathfinder.
    Dan
  • Joe08867
    Joe08867 Posts: 3,919
    My cars are a bit older now but I still like to get them as clean as I can.
    The 00' Impala gets Mothers Wax and Detailing Sprays the 94' VW Golf gets Meguiars Cleaner Wax since it sees more highway miles and is a hard to clean white car.
    Cotton Tee's or White Cotton Towels. Preferably s broken in towel as they seem to get wax off better IMHO.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    billbillw,Nice lookin' Benz...Nothing more stunning than black...when it's clean...and has been recently waxed and detailed by hand...when I say recently,I mean a few seconds ago.
    Black is beautiful,but what a PITA to keep it that way!!!
    Yeah, dust seems to be visible within about 5-10 minutes. I've always stayed away from black, but I couldn't resist when I saw this car. I hope I'm up to the challenge of keeping this one looking nice. Pollen season is going to be a headache.
  • Mike Reeter
    Yea,been there...done that also,that's why our vehicles are white....but my motorcycle is black!! guess I'll never learn
