DV-79AVI for SACD/CD only hook up?
txcoastal1
txcoastal1 Posts: 13,520
You guys have always been a big help...so thanks again in advance
This unit was originally purchased and set aside for a 2chnl rig I am putting together that will have a tube pre and possibly a tube dac, but for now I am tired of looking at it new in the box for the last several months and want to play with it. It will only be used for SACD/CD for music only.
Question is the hook up recommendations should i use:
1)analog L/R for 2 chnl
2)coaxial/optical
3)HDMI
It will hook up to my equipment in my sig
Thanks again
PS: Feel free on any on any recommendation or comments on future 2chnl hookup for the player to Audio Mirror T-61 pre/ and Audio Mirror "TUBADOUR" DAC Mk-II
  • nguyendot
    nguyendot Posts: 3,596
    edited January 2011
    Too bad your new SC35 doesn't have firewire... That player outputs sacd and dvd-a through them.
    Main Surround -
    edited January 2011
    Thanks...cables = mo money
    Then I look at the OPPO95 thread and I hear another cha-ching
    gotta love it
  • mantis
    mantis Posts: 17,694
    edited January 2011
    A very nice feature is having HDMI out and being able to send SACD and DVD AUDIO over it. But if you have to use analog use good quality .
    This hobby will always cost you money. Just get use to it.
    Dan
    edited January 2011
    mantis wrote: »
    I don't mind the money its more the anticipation, I have cables coming from Tom@Aural Thrills I won off agon to play with...all in good fun
    F1nut Posts: 52,406
    edited January 2011
    For the highest quality SACD playback, always use analog cables. Screw that HDMI garbage.
    edited January 2011
    The firewire connection,or as they say, the I-link, I thought sounded better than the analog connections in my 59avi. If your receiver doesn't support it, analog is the only good option left to you.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2011
    Rick88 wrote: »
    I have that unit as well and use it strictly as a CD transport, and it sounds great!
    For your intended use, you should use the analog outs. In fact, to play SACD's you must as the Pioneer doesn't output SACD through HDMI or the digital outs.
    Happy listening!:cool:
    I also own one of these and I swear I've played SACD through HDMI but I could be wrong. I'll check this later on. My preference is always analog but HDMI sounds very decent on DVD-Audio on this unit as well.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
