sound Help
butter21
Well i finally got my new surround sound all hooked up and i went to test it with a movie i can notice that the sound is a split second ahead of the video. My set up is as follows-
Onkyo-708
RTI-A7
CSI-A6
F/xi-A6
My blu-ray player is a PS3 that i have running to the Onkyo via HDMI then HDMI from the Onkyo to the TV...Iv ran the audio speaker setup. Everything sounds great just the lag kills me. Also another rookie question how do i turn my speakers to small on the A/V. Any help would be great.
Onkyo-708
RTI-A7
CSI-A6
F/xi-A6
Post edited by butter21 on
To fix the lag, you need to look in the manual for your Onkyo on how to setup the "audio delay" for your inputs.
As for setting the speakers to small, I also suggest looking at the manual. If you don't have it, you can find it here:
http://www.onkyousa.com/model.cfm?m=TX-NR708&class=Receiver&p=d
