Hole Saw Terror
RuSsMaN
My router has disappeared, among other things. Helping the 8 year old with a school project - needed some 3 - 4 circles cut from ply. I didn't feel like jigsawing them, so I bought a 3 5/8 inch hole saw at Lowes for $16.
I put it on the end of my Dewalt and it was pure terror. Are hole saws only meant to be used on a press? The drill jumped around on the wood, so I set it down firm, put some weight on it, I got some circles cut, but the drill was trying to jump out of my hand constantly, it actually went off the wood and hit me in the leg once.
I should have payed more attention in shop class.
Post edited by RuSsMaN on
Those things can be a beast.
It's best to use a drill with an auxiliary handle on the side and make very light contact at first and then slowly increase the pressure.Sounds good to me... -
Russman, did you pilot the hole first or does the hole saw not have a pilot drill?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
It's got the pilot in the middle, and I'm not touching it again.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
You need to stop using tools.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Ok, I will.
Will you stop acting like one?
(rimshot)Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
....but the drill was trying to jump out of my hand constantly, it actually went off the wood and hit me in the leg once.
What you do in your spare time is your business.
Do you have a drill bit in the center of the saw blade? Use slow rpm. I have had luck reversing the drill to crease the wood for a start. Then forward at a slow rpm to cut. Use a backer board also.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
If you are interested at all....take a large or a blunt brad nailer and hammer it in exactly where the pilot goes. Making sure that the drill and the substrate is level, slowly apply enough pressure to let the pilot go through. Once that is done, check the drill levelness again and proceed slowly to make the hole saw make the initial ring. Once the ring is in about a 1/16th of an inch or more, just make certain that you keep the same [level] path and proceed. With hardwoods, go slow. With soft woods or cheap woods you can go a little quicker. Just make sure that you keep the same path.
This is all assuming you bought the right type of hole saw for the job. In other words, you don't want to buy a hole saw for drywall and attempt to use it on wood.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Polkersince85 wrote: »What you do in your spare time is your business.
Yep and lift the bit out ofter to clean the teeth so the blade doesn't bind. I have to use 4 1/8" hole saws when I do vents at work. In a tight spot sometimes! Yes it hurts when they stop! I like high speed (600-1200rpm) but be very cautious.
Ben -
I tend to prefer having it spinning as fast as possible, too. Higher speed, and only a tiny bit of pressure until it gets started. Just watch it doesn't bite in when you hit the other side of the board.Ludicrous gibs!
Invest in a Milwaukee Hole-Hawg. Life will be easier.>
"Hole Saw Terror?" - is it out on Blu Ray yet? :biggrin:
Chris -
That's a large hole saw to use with a drill."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Keep it level, what a GRAND idea. Just ripped through another dozen circles, without incident. Still scary, still think I'm better off with a press or at least the machine gun handle mentioned earlier.
Maybe it's just because I was sober earlier, and I've had a couple toddies now. Maybe it's like hanging the xmas lights, at 3pm, no one wants to climb the ladder to the peak of the roof, at 8, when everyone is loading up, you can't stay off the ladder.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I guess you don't have the proper tools [or the tools on the tools] to let you do it easily. At least you are not drilling your leg anymore.
Here's to cutting a finger off! :eek:
I keed, I keed. Put the power tools down if you are on the beer. Not a good combo.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I've got a large Bosch corded hammer/normal drill.
Only way to go. A big hole saw just tears up those wimpy
Dewalt gearboxes. Having a big side handle helps a lot, too."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
That's a pretty big hole saw to use free-handed. I drill press is always the ideal scenario for a hole saw. It sounds like your pilot drill bit might be dull or spinning on you. Are you sure you weren't running the drill backwards?DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I actually ran it backwards at first, low rpm, out of pure fear, but the pilot (thingee in the middle with the drill bit) spun loose after a few revs. Brand new saw, says for 'Wood / Metal' on the package. F me, I have no idea. If I got anything out of this, I found out my Dewalt has a bubble level on the **** end.
Cheers,
I hand drilled a whole buncg of 4: holes for my DIY sub's bracing. Christ what a pain in the balls. I feel ya. takes some muscle to stop it from hopping.
the project literally fried my cordless drill, teaching me to not use a cordless drill for drilling big holes.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
I've used hole saws on drills quite extensivly when I was doing outdoor decking. I used it to install drains up to 6" diameter. All the above advice is good except I always prefered to go slow and a handle on the drill is essential. It's the only way to properly controll the torque on the drill body. Just like with knives a sharp saw goes a long way to doing the job right. Good luck.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
For a hole that size, why not just use a router?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
If you're directing this at me, the drains I installed always had to be counter sunk so after the hole is cut (I found the hole saw quicker than the router for the initial hole) I'd use a router to add the counter sink on the outside of the initial hole.
If this was directed at Russ, in his first sentance he stated his router went missing.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
With a large holesaw low rpm high torque is what you need. They can be a bear to control at high speed. Using an angle drill or a variable speed with a handle would be the safest way to drill your holes.
New drill bits an be very aggressive and require a light touch, I usually will contact only a small portion of the edge, and rotate the bit around until you have a nice round groove, then hold the bit flat with the work surface to complete the hole.
Good luck, and don't cut your leg off. -
Holy illegible spam batman...2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
I do believe the thread started out " My router has disappeared".
But for that size hole, hole saw is just fine. If it was 4" or more, time to
go get a cheap router from a pawn shop. Or a trip over to Harbor freight."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
I've used hole saws to drill some 4 or 5" holes in sheet metal and it's never a pleasant experience.My equipment sig felt inadequate and deleted itself.
If this was directed at Russ, in his first sentance he stated his router went missing.sucks2beme wrote: »But for that size hole, hole saw is just fine. If it was 4" or more, time to
go get a cheap router from a pawn shop. Or a trip over to Harbor freight."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
I have a sitting area in my garage, with a pond, a stereo, etc - where I smoke cigs during the winter, so I leave the garage cracked open, sometimes I used to leave it more than cracked - I've had a spare tire, and weedeater also disappear, so it doesn't suprise me that a router may have taken a walk also.
I'm more careful now, but I haven't used the thing in over a year, so I have no idea when it was last here.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
If the hole saw bit had a drill in the middle, how did it jump around?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
