SB3000 conflict with BluRay wireless player
ncpcpa
I have an Insignia wireless BluRay DVD player that I have been using to stream Netflix and Pandora. It worked fine until I installed the SurroundBar 3000 with the wireless sub-woofer. Now, I can't get it to stream. I have tried all four channels, but that did not fix the problem. I have a Netgear N-150 router. I have also tried changing the channels on the router, but that did not fix the problem either. I did not try every permutation of the 4 channels on the SurroundBar and the 11 on the router, but I tried a significant number.
Can someone please provide me a solution to this problem? I like the sound from the SurroundBar 3000 and do not want to have to return it.
Thank you.
Thank you.
Post edited by ncpcpa on
Have you tried switching the router to G mode to test?
Also, does it stream fine when you turn the sound bar off?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Yes. It works fine with soundbar off.
I changed the router to G and it is working. However, that's not the ideal situation since I'm not using the N then. What's your next suggestion?
Thanks! -
Buy a new N router, yours may not be compatible with other wireless devices.Main Surround -
Thanks for the suggestion. I was hoping to find a cheaper solution than that, though....
