weak bass in RTi10
Glad to hear that's working out for you! I haven't found placement to be so critical, but then again, all rooms are different, so what works for one might not work for another. It's amazing what a difference 150 wpc WITH HEADROOM can make. Enjoy!I bought a Adcom 7500 amp for my Rti10's..helped alot in the bass, now i run them "Full Range" also, but...i also angled the Rti10 inward more "Towed in" and adjust the EQ on my SC-25 Xcurve and that help alot also.. Ive noticed these Rti10's need to be place perfect to get the full affect..They sound great now....The whole debate about this topic is,and very simply put..YOU NEED POWER! for the Rti10 and learn how to adjust your EQ on your AVR
Blue light special in appliances!TOOLFORLIFEFAN wrote: »The pretty blue light works though...
Been there, done that...
