Outdoor speaker amplification
edbert
edbert Posts: 1,041
edited December 2010 in The Clubhouse
Alright, so my parents are in the process of creating their dream backyard. It is going to be amazing but I think it will be missing one thing... audio. If having an indoor power source is out of the question, what would you recommend as an outdoor amp/receiver. This would be under a covered patio, but still exposed to high humidity and temps from single digits to 100+.
Any tips or advice is greatly appreciated.
Thanks!
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
  • mdaudioguy
    mdaudioguy Posts: 5,165
    There are some outdoor "weather-proof" amps, but personally, I'd make some sort of enclosure and use an old receiver.
  • jimmydep
    jimmydep Posts: 1,305
    +1 on using an old receiver, it should'nt be too difficult to make a semi-weather proof enclosure.
  • steveinaz
    steveinaz Posts: 19,545
    I buy and use inexpensive used receivers. The Yamaha out on my patio now, has been outside 24/7 for 6 years, and is still running fine! I think I paid $40 bucks for it.
    Here's a video of our place, towards the end you'll see the patio rig:
    http://www.youtube.com/watch?v=kxFGhUq7X5M
  • Sherardp
    Sherardp Posts: 8,038
    I would use the Zone 2 speaker terminals of a receiver or just buy cheap receiver and hide it in the bar area/pool house or something similar. Atrium 60s are a great choice for outdoor speakers also.
  • madmax
    madmax Posts: 12,434
    So long as you have it plugged into a gfci (or whatever it is) circuit I see no problem with a receiver in a box.
    Vinyl, the final frontier...
  • mantis
    mantis Posts: 17,380
    It's not a good idea to have gear in extreme weather conditions especially heat. They will fail prematurely. I suggest putting the gear inside the house , in a basement or at least in a location with controlled temperature.
    You can run speaker wire out to all of your outdoor speakers with Direct burial wire which can get wet and be put in the ground.
    Pay attention to your connections at the outdoor speakers use silicon or a dielectric grease on the speaker binding posts.
    As far as what to use , use a Niles multichannel amp and a preamp of your choice. It's good to have control RF or IP outside so you can bring a controller out like a Ipad , Iphone or a Universal RF remote.
    Dan
