Compatibility on RM6750
Faiz
Faiz Posts: 1
edited January 2011 in Troubleshooting
Hi All,
I am new to this forum and to the Home Theater World.
I recently purchased a Onkyo TX-SR508 7.1 receiver and RM6750.1 for my apartment. The performance does not seem to be very satisfying. Hence I wanted to get suggestions on the compatibility? Both products individually had very good reviews on Amazon. My question here is whether they are compatible systems. Is the compatibility causing an issue in performance?
Any suggestion, guidance is highly appreciated.
Regards,
Faiz
Post edited by Faiz on
    edited December 2010
    How do you have it all hooked up to the receiver ? What is it exactly that you don't like about the sound ?
    Sounds to me like that system may be too small for you.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    I used an RM6750 set for one day. It wasn't very satisfying for me either. Those speakers are small, even for satellites. You have no choice, but to upgrade. Try bookshelves.
    Good luck, and welcome to Club Polk!
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2011
    mdaudioguy wrote: »
    I agree unless you have a very dmall room. What is your chance of returning? I would also suggest you try the new Blackstone; http://www.polkaudio.com/homeaudio/blackstonetl/. Check if Mark (Doro) would allow you to demo them. I would also wait for the TL3 to come out soon if the TL1 do not deliver as you want.
    BTW, what size is your room? Oh and welcome to Club Polk Faiz:smile:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
