PSW10 amplifier replacement
RichB
RichB Posts: 1
edited December 2010 in Troubleshooting
My PSW10 recently quit powering up. Polk replaced the amplifier under warranty and I am currently attempting to install it. I have the defective part off but I can't figure out how to connect the new one without completely disassembling the speaker cabinet. The connector for the amplifier is behind a piece of particle board. I can't see behind it and fumbling around with my hand has not produced any success so far. Does any one have any tips, suggestions, or diagrams/documentation?
Thanks.
Post edited by RichB on
  • [Deleted User]
    [Deleted User] Posts: 1,225
    You'll need to remove both amp and driver. Remove the driver and disconnect the amp leads. Feed them back through the particle board and then remove the amp. Feed the new amp output leads through the particle board, install new amp then re-install the driver. Hope this helps.
