Sub to blend with Martin Logans
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited December 2010 in Speakers
As I look through all the 2k subs ML sells and how I can not afford that right now. I bring myself asking is their a cheaper alternative that will blend well with them? I usually only use the sub when I watch movies and I find them lacking right now with no presence of a sub.
I will be buying a amp for my ML's in a few weeks which will allow them to show their real potential. I am going to run them with a amp that will produce 240-300 watts at 4 ohms.
Any ideas for a sub to match with these? The one I was looking at was the ML Depth i
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • jinjuku
    jinjuku Posts: 1,523
    If you are worried about timber matching I wouldn't. You could look at Rythmik Audio. They have some really stellar sealed solutions and are servo controlled.
    Their upcoming FV15HP will have a review out for it Monday in a multi-sub shoot out so you can see it comparatively. From the rumblings from Rythmik at AVS forum the sub has fared well.
    HSU VTF-15H
    Rythmik FV15HP
    Funkywaves FW12.X SA1000
    SVS PB12-Plus
    Salk SongSub
    RBH Sound SX-12
    These are all part of the shoot out and the results will be available Monday.
    tonyb Posts: 33,019
    I'm not into subs today as I was years ago, but if I was you, I'd be looking for a fast, musical sub as those ML's are a tad faster than a box speaker. Subs are not voice matched, but rather speed matched. The subs I used to like for speed, musicality, and down right power, were those from Rel, the older revel B15. Of coarse today the field is wide open with Velo, HSU, SVS,EPIK, Dayton...and more, that can knock down walls if you so desire. Thing is, don't go cheap on a sub. You can get a really nice one for around 800-1000 bucks used. Audiogon has a good variety of subs. Take a peek.
    pitdogg2 Posts: 25,715
    How about a ML sub they make them
  • concealer404
    concealer404 Posts: 7,440
    About how far do your MLs go down to with authority?
    I ask before i recommend my old budget standby. (Omni S8/S10)
  • jinjuku
    I guess the ML's he's looking at are too expensive
    my bad I must of read through too fast.
    I had seen one in audio advisor mag they sent I didn't think it was that expensive (2K).
    your best bet will be to buy used for what you want to spend you could get a darn nice sub
  • concealer404
    I don't think the ML Depth or Grotto are that expensive, might be worth a look. Though if i remember correctly, they're more HT-oriented.
  • bigaudiofanatic
    Well here is the depth i which is 2,200 bucks maybe a bit cheaper else were.
    http://www.martinlogan.com/products/depthi
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    tonyb Posts: 33,019
    http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1297132683&/SVS-pb12-nsd
    Some here who have this sub rave about it. Have no idea if it's fast enough to keep up with the Logans though. I would assume so since a variety of speakers are being used with it.
    http://www.audiogon.com/cgi-bin/cls.pl?homesubw&1297712066&/Martin-Logan-Depth-fast-bass--
    More of a match for you.
  • bigaudiofanatic
    tonyb wrote: »
    Ya I am not trying to knock down walls just want something to be heard or felt when I play avatar of transformers.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • ben62670
    ben62670 Posts: 15,969
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-764
    I had two of these and it was overkill!
    Ben
  • rdb2001
    rdb2001 Posts: 791
    what is your budget?
  • dorokusai
    dorokusai Posts: 25,577
    I think the REL has been the best subwoofer I've found to blend on the higher end....the Polk DSWPro series is a very good cost alternative and includes DSP room modes. You don't need a huge subwoofer to compliment a electro or planar, just a quick fast subwoofer to handle the last lower octave(s).
  • concealer404
    Dammit. I was thinking of the Dynamo, my bad.
  • blueboxer
    blueboxer Posts: 621
    There are a couple used JL Fathom 110 on the gon right now. I have been considering getting two of them, but my downstairs room won't permit it. :(
  • madmax
    madmax Posts: 12,434
    I had one of these built by DecWare and it is the fastest best sounding sub I've heard to date! Price was good as well.
    madmax
    http://www.polkaudio.com/forums/showthread.php?t=86421&highlight=subwoofer
    Vinyl, the final frontier...
  • jinjuku
    Wuss :biggrin::eek:
    If the Alien emerging scene from War of the World doesn't knock your 6 month old infant out of their high chair, you just might be an audio noob.
    If cannon exchanges in Master and Commander don't cause your poodle to loose control of it's bladder, you just might be an audio noob.
  • pearsall001
    pearsall001 Posts: 5,093
    I'm running twin Velo SPL-1200R subs & they definetely get the job done for both HT & two channel. Very fast & extremely musical for two channel & plenty of "umph" to handle anything HT related.
  • mantis
    mantis Posts: 17,204
    My Man Martin Logan makes their own subs as you know and they blend perfectly with all of their speakers. They are extremely fast and musical.
    When they first came out with subwoofers back O about 10 years ago or so , I was completely blown away by their performance. We had the martin Logan rep come in with the Depth and Decent and I could not believe the quality of bass coming from those woofers. You really need not look at anything else , the bus stops here bro.
    But...
    As mentioned above , Rel makes some killer musical subs. They are not the best in the world for a theater( I like the Martin Logans better) but they are about as good as it gets for 2 channel music and blending with "ANY" 2 speakers. It's amazing how good they are.
    Both of these sub companies are where it's at.
    Dan
  • bigaudiofanatic
    Looks like I am saving up 2k for a ML sub.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
