Psw10
jerseycy
I haven't been able to get mine to work for some time. Have direct connected the towers through the subwoofer, and they work, the center works and the surround works - nothing from the sub woofer. Switches are on, setting on the Denon appear to work. No power light, no sound whatsoever from the woofer. Does this thing have a fuse inside or something affecting power? The outlet is good. Have kind of given up. Thanks.
