r50 tweeter
marms
marms Posts: 7
edited December 2010 in Troubleshooting
So i replaced a blown tweeter in the fall and changed the receiver. Today i noticed that the same tweeter is crackly again. I guess my question is do the R50 tweeters blow easily or am i doing something wrong?
thanks
Post edited by marms on
  • Knucklehead
    Knucklehead Posts: 3,602
    well, I had R50's never had any problem with the tweeters although I have read they were susceptible to damage from being overdriven, so Im guessing that may be what happened to yours.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • dorokusai
    dorokusai Posts: 25,577
    Clipping and/or being overdriven. Since they are easy to drive I'm thinking simply too loud.
    What Receiver or AVR are you using Marms?
  • marms
    marms Posts: 7
    i had an older dennon one...not sure what kind. But after replacing the tweeter using a sony DA333ES
  • dorokusai
    That's a much better AVR, guessing....love the DAxxxES series. Chill out on the volume knob :smile:
  • mrbigbluelight
    mrbigbluelight Posts: 9,833
    You might consider checking your connections to your speakers, too.
    Loose connections or faulty wiring can cause some problems.
    You have any pets that like to gnaw on wiring ? We had a rabbit that did, but only on the power cord to the AVR. How that rabbit didn't get cooked is anybody's guess.
    We've driven our R50's using both an Onkyo and a Dennon AVR to levels that were certifiably stupid ("Fast and Furious" .... ahhhhhh !). Could have (shoot ... probably should have) caused damage, but didn't.
    Doro's advice is good, though; keep an eye on the volume knob.
  • madfin
    madfin Posts: 11
    I just replaced the R50 tweeters with vifa d19td-05 and to my surprise sounds really good, however you will be required rout out the tweeter hole a little larger and change out the .05ohm resistor in the crossover very easy to do. I purchased the vifa tweeter and resistor from Parts Express and you can read my review on how I made the project work on their web site.
