"Popping" Noise When Powering Up?
Gulfstrings
Gulfstrings Posts: 313
edited December 2010 in Troubleshooting
I've noticed a popping noise thru the speakers when powering up lately. It's that typical 'pop' we've all heard before but it seems to be getting louder.
Marantz AV7005
Marantz MM7055
Onkyo DX-755 CdP
Oppo BDP-93
Technics SL-1301/Shure M97xE
Polk RTi A7s
Polk CSi A6
Polk FXi A6s
Velodyne VDR10-BV
Panamax M5100-PM
Antec VERIS A/V Cooler x 2
Post edited by Gulfstrings on
  • AudioGenics
    AudioGenics Posts: 2,567
    edited November 2010
    what kind of gear - amp and speakers ?
  • hearingimpared
    hearingimpared Posts: 21,136
    Does the popping occur when the volume is set to minimum? and ^^^^ what he asked.
    treitz3 Posts: 20,206
    Onkyo TX-SR707
    NAD T955
    Onkyo DX-755
    Pioneer BDP-320
    Cambridge 640P
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    To the OP....Is it just your sub making the "pop"?
  • hearingimpared
    Duh!!! Nice catch Tom. When my T763 was starting to go south, it gave me that popping sound when taken out of sleep mode. After awhile, I just lost all sound. It turned out to be a manufacturing defect and NAD replaced it with a T765.
  • AudioGenics
    meant to say Which amp and speakers ?
  • Gulfstrings
    The startup volume preset is 45 db. But it didn't do this at all until a few weeks ago.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • Gulfstrings
    Okay. I just played around and the pop definiteely occurs when the NAD is powered up. The onkyo doesn't cause it but it is only the "pre" in my setup.
    Starting to think the NAD may be the bogey.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    F1nut Posts: 52,150
    Sounds like a bad mute relay in your amp or a bad cap.
  • Gulfstrings
    Here's what I've got so far.
    1. The issue is a POP when powering the NAD from the right front speaker
    2. I reversed the pre-out cables from the Onkyo on the rear of the NAD, left front and righ front (one and five)
    3. The POP stayed with the right front speaker
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • AudioGenics
    final check
    swap left / right from Nad to speakers
    verify that issue will follow.
  • Gulfstrings
    final check
    Yeah ... I actually hooked up another speaker (too much weight to be moving around) to the speaker wire from channel 5. POP and dead.
    Believe it or not, this is the first piece of electronic (not computer) hardware I've ever had fail. I'm pissed!
    Audio Advisors gave me the name and number of a local NAD repair shop - and I trust the warranty will take care of this, but I'm still pissed!
    NAD had best take real good care of this issue ...
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • hearingimpared
    Trust me bro they will. As I posted earlier they replaced a four year old T763, which was their flagship at the time and I was the second owner, to a T765 with no problem at all and the T763 was out of warranty too. The only thing I had to pay at the time was shipping the T763 to their facility in Connecticut. Their customer service is akin to that of Polk's.
    They did the same for Phil (pearsall001) . . . same deal and his was five years old.
  • Gulfstrings
    Okay. Much calmer now. Thanks. Here's what's happening:
    I phoned Audio Advisor Sunday afternoon. They gave me the name and number of NAD's warranty repair shop right here in the Tampa Bay area.
    Phoned said warrenty repair shop this morning and the man asked me about the process I used to determine the problem was in the amp. Check, it's the amp.
    He commented that this amp was "bulletproof" and that he counldn't remember seeing one in for repair. He then said, "Don't worry. We've worked with NAD a long time and it will be taken care of."
    Other than having to move that heavy sob in for repair - and with the much appreciated positive comments above, I'm feeling much better now ...
    Dave
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • hearingimpared
    Dave
    LOL! Dave, I forgot to mention having to actually move the heavy SOB around. What irritated me the most was having to disconnect alllllllll those wires and cables with only about two inches of space and then reconnect!:eek:
  • Gulfstrings
    I took the amp to the repair shop today. Husband and wife team with a tech or two and enough electronic stuff around to assure me I was in the right place.
    Ten days to two weeks turnaround time (or for $50 you'll be the next workorder) and a professional workorder it was with a printed copy for me and corresponding barcode for the equipment. Feeling pretty good here. Then when Sarah (owner's wife) said, "NAD is great to work with and this won't cost you a dime. They are timely in paying us to take care of their customers."
    Feeling better. Now we wait ...
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • hearingimpared
    Just an FYI Bro. I had my T773 in the shop three times and they found no problems. When I would get it home shortly after a movie started no sound. Finally the owner of the repair shop suggested contacting NAD customer service . . . that's when they replaced the unit with the new unit T765.
    If you have this experience, don't keep taking it back to the shop call;
    Bob Moran
    Lenbrook America
    1-800-263-4641 ext 4342
    1-800-263-1555 (fax)
    He will take care of you pronto. Again that is if the repair shop can't fix the problem or you have recurrences of the problem.
  • Gulfstrings
    Bob Moran
    Lenbrook America
    Whoa! Thanks much for this! Wonder what the heck was going on that your shop couldn't find the problem. Not sure it matters, but were they NAD authorized for warranty work?
    I'll keep my fingers crossed that it can be repaired but really good to have this just in case. Thanks again!
    Dave
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
  • hearingimpared
    Dave
    Yes, there are an NAD authorized warranty shop. The reason they couldn't find the problem or fix it because it was a factory defect.
