My custom SDA cable
Toolfan66
Well I was organizing my closet full of audio crap most of it is Polk Audio Parts, and I came across some Audio Magic (spector) speaker cables that I have had and never used. I also found a box of Audioquest bananas as well.
My 1.2tl's have been modded for a banana plug for the SDA cable.
So my brain went into a quick project mode
I went out to the garage grabbed my soldering iron, Cardas solder, and some shrink tube.
This project took all of 15 minutes..
This is silver wire in this cable. I cut and twisted both wires and soldered them (I did not take a pic of this) too fit better in the bananas, and of course used the shrink tubing to finish it off.
I have enough cable and bananas to make one more if I ever needed it..
Fun quick project for the cost of some crap laying around doing nothing. I will put it in my rig today.
By the way my parts closet looks so much better with everything being in it's own box.
Post edited by Toolfan66 on
this will only work on your custom binding post right?
Yep, I eleminated the Pin/Blade outlet and put in a binding post.
Jesse (F1nut) sent me a Pin/Blade end that has been split in half and the Blade is just there for support. Both wires in the cable are soldered to the Pin.
It is fact that the blade does nothing for the SDA signal.. -
if I ever change mine out I will just use binding posts and speaker cable.
Nice work! I thought you would cut some custom jumpers out on your laser though.
Thanks!!
I went with Cardas Jumpers from Sonicraft. -
does the word "Hoarder" come to mind? lol this is what I had at one time:redface:
Attachment not found. -
No effin way!! Holy crap!!
The bigger white boxes are all Polk parts as well.. I got these boxes just to clean it up a little It was a mess.
I added about four more pairs after that and then got together with my wife then GF and started selling them on CL, they're all gone except for the subs a center and some realistic minimus 7.
its looking like a Polk wear house Larry
TOOLFORLIFEFAN wrote: »Yep, I eleminated the Pin/Blade outlet and put in a binding post.
While it is true that the blade is only used for support in the regular SDA cable, the blade in the AI-1 SDA cable is connected to one of the wires.Political Correctness'.........defined
President of Club Polk -
Thanks for that info!! I should have guessed that. When I was modding these I was wondering what the little white wire was for on the inside going from the blade on the binding post cup. Now it makes sense..
Thanks Jesse. -
Damn Larry!! your the envy of all that is one nice set up you got going there
Ivan -
Ivan
Thanks!!
I like having the extra parts as much as I do the speakers.. -
Can you say driver hoarder!. No wonder why it took me 6 mouths to find a 6511 Larry's been buying them all.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
TOOLFORLIFEFAN wrote: »Thanks!!
Agreed. You should always have extra parts for your main speakers. At the very least one driver of each.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
How are those jumpers Larry?
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Greg
I like them, I found them to be a nice upgrade. I know I could have built my own and I did with some speaker wire I had laying around. But I was ordering from sonicraft and just added these to my order.. -
Don't suppose I could get one of those 6510s:biggrin:
Nice work Larry...man you have enough parts there to build you a set of custom cabinets..Maybe thats what you need to go next..start selling custom cabinets to go with people's drivers.
That's a great idea to convert that pin/blade to a banana plug. Have enever been able to locate a factory SDA cable for my 1c's. I may have to "re-engineer" now that I've seen your handywork Larry!Life's too short too listen to bad speakers
Talk about a wall of sound....
Are those Sony MF-SS515's along with their smaller brother on top? ?3rd row in? I have a pair laying around and have read that replacing the xover will make a huge difference, always liked the sound out of them... -
You would have been very popular at AK.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I'm just curious what happens if the cleaning crew plugs it back in wrong. Your just removed a significant layer of idiot proofing.:biggrin:Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
