What speaker wire to choose for my new setup?
myke
myke Posts: 138
As the title suggest, I have been piecing together a new HT and wanted some advice on speaker wire. Is monster a very good fall back, how about best buys rocketfish? I don't want to break the budget and don't believe I need the BEST, but I would like something (very) good to compliment my new speakers. Check the sig for the speakers, btw, if it helps I use my livingroom as my theater room and its about 20'x15'.
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
  • messiah
    messiah Posts: 1,790
    edited October 2010
    You can get 12 gauge wire at monoprice 100 ft roll for 23 bucks. Much better than anything best buy has. It's just basic cable, but heavy enough for long runs.
    BTW, what are AudioPhile towers?
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited October 2010
    Or if you're running it in the walls, which will look much cleaner, get something like this:
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=101-207
    Home Depot, Lowes, or any hardware store should have something similar, if you don't want to wait for delivery.
  • mantis
    mantis Posts: 17,419
    edited October 2010
    Audioquest Flex 14-2. It is hands down the very best sounding in wall speaker wire I have ever used. I use it on my current system now and love it. I used it on my Dynaudio system.
    Buy it and your done. I spec'd a 250 roll due to the size of your room. You probably will use about 150 to 200 feet depending on rear speaker runs.
    http://www.crutchfield.com/p_703142250/AudioQuest-FLX-14-2-14-Gauge-In-Wall-Speaker-Cable-250-feet.html?tp=1432
    Dan
  • messiah
    edited October 2010
    I have some of the flex 14/4, and it is indeed very good wire.
  • myke
    myke Posts: 138
    edited October 2010
    Messiah,
    I meant to write AudioFile 583LR in the signature line. I'll update it thanks. Thanks for the input too guys, I want in-wall but might be moving soon and i'm not sure when. However, I do want to hook up my now side speakers for 7.1 (just to try and experiment vs 5.1) but don't want to spend too much cash for what might be a short term solution. Btw, how do you guys put them in the wall (ie:is there a special tool for cutting strips in drywall) with the studs going vertical, thats a lot of studs to go through?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • myke
    myke Posts: 138
    edited October 2010
    Another stupid question,
    I noticed flex 14-2 and 14/4, is the four for bi-wiring, is that for 5.1 only, and where do the extra wires go on (come from) the receiver?
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • messiah
    edited October 2010
    With the 14/4 there are 4 wires on each end (red, white, green, and black) I have the red and wired together to form one wire (positive), and the green and black together to form the other wire (negative). There is no benefit of getting the 14/4 over the 14/2 other than to have a larger gauge wire. It's just what someone happened to be selling, and I wanted to try it out.
  • grimmace19
    grimmace19 Posts: 1,429
    edited October 2010
    I run my fronts with canare 4s11 from blue jean cable and love it. I'm sure there is better out there but for about a buck a foot it's hard to beat. I liked it so much that I got rid of my AR Master series cables that I previously used.
    And for my backs I use the Belden 5000 cable that they offer. For .50/ft it's working great and was easy to work with.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2010
    www.signalcable.com or whatever you want. PLEASE NO Rocketfish before you look into the aforementioned brands by the forum.
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    The Canare 4S11 is great wire for the price. The AudioQuest 14/2 is another good wire, but the 4S11 is better for near the same price.
    Ben
  • sm88
    sm88 Posts: 353
    edited October 2010
    I also have used the BJC Canare 4S11 and it is excellent given the price, get the locking banana plugs, they are fantastic; I've got a bi-wire pair for one system.
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2010
    myke wrote: »
    Messiah,
    Just an FYI - you know the Audiofile speakers are white van speaker scam speakers, right?
    Main Surround -
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited October 2010
    ben62670 wrote: »
    +1
    The Canare 4S11 is a great budget cable. I've got a pair of 4S11 cables for my 2 channel rig that I terminated myself with GLS Locking bananas...and they sound great. They look great too if you follow this guide like I did...
    http://audiokarma.org/forums/showthread.php?t=94203
    I've also got a pair of Audioquest Type 4 speaker cables, which are what I'm currently using. The Type 4's and the 4S11 have a very similar geometry...both being a star quad configuration. The Type 4's have a slight edge on the 4S11, but it's not by much. I've found the 4S11 to sound a tad bit more neutral than the Type 4's, where the Type 4's a little bit warmer sounding, with a slightly more defined low end...which in my system sounds better to my ears. In other rigs though, the 4S11 could very well come out on top of the Type 4's.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • dorokusai
    edited October 2010
    Canare cable is ok but I've never liked their connectors very much. They always felt cheap and the strain relief boots are the same way. I'd also pick Canare over Monoprice if forced by gunpoint to do so....but either one is a step up from lamp cord.
  • messiah
    edited October 2010
    By gunpoint....:D Priceless :p Thanks Mark! Just made me laugh as I've never heard anyone say "If a gun was put to my head, I'd pick this wire" lol.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited October 2010
    nguyendot wrote: »
    I'm sure they'll be fine handling surround duty. They're only scam speakers if he paid like $500 for them.
  • myke
    myke Posts: 138
    edited October 2010
    Yeah I know they're scam speakers, but since my neighbor gave them to me before he left the country I don't feel too scammed. In-fact, they're actually not that bad, they can certainly handle loud volumes and for free that it makes them sound even better:) As mentioned in an earlier thread, they are side rears now until I can save more. Ultimately I want the RTi A bookshelf and FXi surrounds to round out my HT.
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • resperc
    resperc Posts: 41
    edited November 2010
    I wired my Dad's system with 12 guage stuff from BlueJeans and it worked really well. It isn't the absolute cheapest, but it is definitely in the affordable range compared to many other options.
