...plastic scratch remover???
dee1949
dee1949 Posts: 1,425
edited October 2010 in The Clubhouse
....has anybody tried this or any other product that might work?? Have an AR_XA tt that the lid has multiple swirl scratches. Would like to restore it.
http://www.amazon.com/NOVUS-PC-20-Plastic-Scratch-Remover/dp/B002UD0GGS/ref=pd_sim_dbs_sg_5
Post edited by dee1949 on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2010
    Me and my father use that stuff for our helmet visors. Other than that I do not see it working for harder plastics.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • Vette C6.r
    Vette C6.r Posts: 1,560
    edited October 2010
    Meguiars wax had a good platic polish. It came in a smaller white bottle. I was great for plasic conv. windows.
  • mantis
    mantis Posts: 17,209
    edited October 2010
    Vette C6.r wrote: »
    +1 , thats what I use.
    Dan
  • miner
    miner Posts: 1,305
    edited October 2010
    ScratchX by Meguiars.
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2010
    miner wrote: »
    scratchx by meguiars.
    +10000
  • steveinaz
    steveinaz Posts: 19,538
    edited October 2010
    Yep, scratch-x. Novus is more of a plastic shield polish---very good for that. I used it also on my sportbike windshields (when I had one) and my helmet shield.
  • steveinaz
    edited October 2010
    ..to add...if Scratch-X doesn't have enough abrasiveness, buy some 3M polishing compound (keep it well shaken) in the black bottle, it's a little coarser for deeper scratches--then follow-up with Scratch-x. Sometimes it's necessary to use some 600 or 1000 grade wet/dry polishing paper first. I use 600 wet/dry (wetted) then scratch-x to restore my cars headlight plastic covers. Then I follow-up with wax. They look like new.
    If you just have some "spider-webbing" type very minor scratches, Scratch-x should work perfectly.
