Media server
ryanjoachim
I'm in the market for a media server/player (think WD Live HD). Price needs to be $100 or below (a little above might be do-able...if it's worth it).
Needs to be able to stream 1080p MKV files from a server to the tv via HDMI and bitstream HD audio.
It's a lot to ask, I know.
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
The only media server thats under a 100 bucks is the new Apple TV. Roku is higher , but check out squeezebox , it's pretty cool but I believe also out of your price range.
Good luck with getting something under 100 bucks and do all you want it to do.Dan
Perhaps a used PS3 with VLC or Media Center 15. I use these with excellent results.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
WD is a nice unit. I do not have the live but the one I have using an external dac for FLAC files does a nice job. Rip DVDs to it and does a nice job.Speakers: SDA-1C (most all the goodies)
Yeah, i'm really leaning towards a WD unit...but $100 is still steep for me right now, which is why I was seeing if anyone had something used they wanted to get rid of."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
I have an IO-Box 100HD (not for sale but I wanted to tell you about it). I got it from gizmodaddy and it works great. I found that playing the mkv files are kind of tricky and the IO-Box has never failed to play a format, codec , etc. There are other devices similar but have limitations. It's $169.
I put a 1TB hard drive in mine but it will run without it. Connects to your network and can access folders on a PC to play movies, music, or pics. SAMBA (allows you to map a drive letter to it from a PC) and a few other services. You can even plug a flash drive, usb hard drive, etc into it. The box has a network interface, hdmi, component video, optical and digital coax audio. Nice all around media tank.
Let me know if you want to discuss further / need more details.
jw -
amazon.com
99.99 free ship
Iomega Home Media 1 TB Network Attached Storage 34337
