polk momo 6.5 component spkr SEIZED
madmike3434
I have a set of polk momo 6.5 component speakers with seperate tweeters and polk momo crossovers, this is all from the SILVER EDITION .
When installing the speaker today i could not get any sound out of it, then i noticed that the woofer cone was rock solid and nothing in the woofer would move.
Anybody have any idea what has happened here and if this speaker can be repaired ? :mad:
thanks
..........mike
thanks
Post edited by madmike3434 on
Had a set that I installed and the car sat for about 5 months Went out to take the car out and sure enough mine were rock solid from moisture getting into the woofer. I have seen it before and just changed them with something else.
Also a lot of wattage like 500 or so for 40 seconds would do that as well.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
thanks big audio. I bought them as a used complete set off ebay about 5 weeks ago. Now to see what seller will do. Luckily there is more on ebay brand new. Will also have to see if it can be loosened up and repaired ??? Hate to throw away quality item.
mike -
while i am at it, anybody got an extra polk momo woofer 6.5 they want to sell. Contact me at mike350 at rogers dot com
thank you
mike
