Help me improve wifi reception Macbook Pro
Ern Dog
Ern Dog Posts: 2,237
edited October 2010 in The Clubhouse
My wifi reception for my Macbook Pro is mediocre. It will sometimes drop out or go real slow. My internet is through a satellite because I live in the mountains. The router is in the garage because I'm sharing it with my landlord and the garage is in the middle.
I know getting an Airport Extreme base station would help, but that's a $179 solution.
Anybody ever try one of these $40 Wifi Boosters: http://www.betterwifirange.com/?gclid=CIXzjq_esqQCFQsEbAodxS5y0Q
Any other inexpensive suggestions?
Thanks.
Post edited by Ern Dog on
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2010
    Actually hate to tell you but macbook pros have some of the best reception. I to have satellite but my router is in the basement. Are you running a N router? You could also use a replicator or extender to boost the signal as you posted.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • Ern Dog
    edited October 2010
    Lasareath wrote: »
    I've tried boosters with mixed results. The best way is to run an Ethernet line to the cable modem and into your apartment then hookup your own wireless access point.
    Can't do that because I'm sharing it with my landlord, so I need to keep the access point in the middle between us.
    Is there a booster you recall that worked well?
  • xsmi
    xsmi Posts: 1,798
    edited October 2010
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • greg2350
    greg2350 Posts: 544
    edited October 2010
    Ern Dog wrote: »
    I think Lasareath was saying to run a second access point keep the 1 in the garage and run a ethernet cable to your apartment and hook up a second access point.
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • mantis
    mantis Posts: 17,189
    edited October 2010
    xsmi wrote: »
    +1,
    You need to hard wire it to your network closer to where you use your Mac , then set it up to extend your wireless network. It works excellent when hardwired but not so good if you try to go wireless to wireless.
    The Airport Extreme is worth every cent of 179.99. You will pay this or more for a good high quality router. Anything under a 100 bucks is crap unless you have no demands on it then the lower budget routers are fine.
    Better routers better NAT tables better traffic and management.
    Dan
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2010
    +1 with running a hardwire from the 1st modem to your room, then setup additional wireless N router. You could run a small switch too.
  • Ern Dog
    edited October 2010
    Cool, thanks guys for the suggestions.
  • Ern Dog
    edited October 2010
    Oh, one more thing. What the difference between N rounters and G routers? One better?
    Further looking and I found out that I'm using a D Link WBR 1310. Looks like it's a cheapo. Is there a better one people would recommend? Has to work with Mac and PC.
  • mantis
    edited October 2010
    N routers are 1000 and G routers are 100. In wireless the G can work up to 54 and N can go around 300 or so.
    I plain terms the N routers have the ability to send more data both wired and wireless. This does not give you faster internet. A G router 10/100 will run just about every single USA connection to peak , it's computer to computer and wireless is where you will benefit from the N routers.
    When it comes to Networking , if you buy "the cheap on" you are asking for problems. Buy the best you can afford , it will pay down the road.
    I think you should get a Apple Airport Extreme router , yes they cost more but they are rock solid. I use them in big jobs big networks , guest networks and lots and lots of traffic without any problems or slowdowns.
    You already own a excellent Mac why make the experience less then what it can be?
    Dan
    Dan
