Lack of Lower frequencies in my RTi38
gacilu
Hi,
I started to make a home teather system at home and I decided to start with an small system but with a big future.
I only have the front speakers with a subwoofer.
I have RTi38 pair at front and a PSW404 as a subwoofer. My receiver is a Marantz SR4300.
At the beginning I connected the PSW404 to the Sub preout of the Marantz and the RTi38 to the front channel, but there was a hole between the Front and the Sub. The male voices seems to be lost.
After that I changed the connections, following the instructions in the subwoofer guide, and I have connected my front RTi38 across the subwoofer and I set up the Marantz without a Subwoofer . The sound is better, but the low male voices still are not as good as I would like.
Do you have any suggestions to improve the performance?
Thanks for your help.
Post edited by gacilu on
CSi30 perhaps?
Are you talking about the home theater experience, as in movies? I can't think of why there would be a hole in the frequency spectrum with your setup, but a center speaker would provide a more direct relationship with movie dialogue.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
How is your bass management configured for both set-ups (the sub cable and the speaker wire method)?
By bass management, I mean the receiver settings for speaker size, and subwoofer crossover frequency, etc.
It might help identify why there is a problem with male voices.
Doc"What we do in life echoes in eternity"
SVS -
If you have your setup running DD/DTS/Etc movies, and are trying to do that thru only 2 speakers(L+R), it will sound "hollow" without a center channel. I know what sound effect you are experiencing and that is possibly why.
It is almost like you can't hear what is going on right? Dialogue that is....
I would go back to your first setup after buying a center channel. In the meantime just play your movies in 2 channel mode, you won't get a HT experience with 2 channel but it will certainly be loud.
*EDIT*
I should have said possibly why, sorryCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
it could also be something as simple as the wiring on your speakers might be wrong too. this will cause a loss in bass. check to make sure your pos (red) goes to red on your receiver. and the same for neg (black).
good luck, AlPolkFest 2012, who's going>?
