Tweeters Shutting off
Valentine
Valentine Posts: 46
edited September 2010 in Troubleshooting
Hello everyone im new to the polk forum, i have heard if you have a polk question or problem this is the place to get the answer you need. What i have is a pair of SDA-1C. This is the issue the tweeters are shutting off, ok this is what i think might be happening is the polyswitch (i believe is what you call it) is opening and they are shutting off. That what ive found from a little bit of research. If anyone could help me with a little more detail it would be greatly appreciated .
thank you for all of your help. Mitchell Valentine
Post edited by Valentine on
  • ben62670
    ben62670 Posts: 15,969
    Pull your crossovers out and bypass them. Take a couple pics of them so we can help you identify the poly switches.
    Welcome to Club Polk.
    Ben
    Ben
    F1nut Posts: 52,011
    It's never a good idea to suggest removing the polys without knowing what the person is driving the speakers with and how loud they turn it up.
    So Mitchell, what say you?
  • Valentine
    Valentine Posts: 46
    Ok this is my crossover i've had it out for a couple of days.
  • Valentine
    Valentine Posts: 46
    I run them with a parasound a21, i usually keep them at a respectable level with just listening, but i do have 1 night a month (DOMINO NIGHT:D) i kinda forget that they are 20 some years old.
  • ben62670
    The little blue thing by the word input is the Poly switch. Bypass it and if you hear any distortion while cranking it turn it down.
    Ben
    Ben
  • Valentine
    Valentine Posts: 46
    ok one other question why'll we are on the topic, since i have the crossover out should i look at doing mods to them or just let them be.
  • ben62670
    If you are confident in your soldering skills mod them. If you are not confident with your skills you can send them to me. I do many XO's for Polkies.
    Ben
    Ben
  • Valentine
    Valentine Posts: 46
    well email me with cost of parts, labor and shipping, and what you mod and ill take a look at it.
    this is what ive done so far:
    Spiked/mortite/dynamate/rdo-194's (not to impressed with this one)
  • george daniel
    george daniel Posts: 12,096
    You might wanna' consider a set of Larrys' rings while you're at it.
