FXI5 Broken Grill pin
teamjhertz
teamjhertz Posts: 363
edited October 2010 in Troubleshooting
It turns out two of my dowel pins that hold the grill on my FXI5 cracked in half flush with the speaker cabinet. I received two replacement dowel pins from Polk (A+ for customer service) , but I was wondering if anyone has successfully drilled or milled out the old dowel pins. Or do you think I would be better off trying to fix the old pins by using super glue or epoxy?
thanks
Post edited by teamjhertz on
  • ken brydson
    ken brydson Posts: 9,011
    edited September 2010
    teamjhertz wrote: »
    thanks
    Had the same issue with my LsFx's. Soiset posted the following, worked great.
    If you still have the pegs, you can fix that grill very effectively. You need a 1/32" drill bit, a paper clip, and some CA glue, preferably gel type. Drill holes in center of peg and where the peg used to be on the grill. Cut a 3/8" length of the paper clip, and insert with glue into the peg, then apply glue to the peg and surface, and mount. It's there for good.
  • teamjhertz
    thanks for the trick it sounds like it will work.
  • teamjhertz
    edited October 2010
    I finally got around to making the repair. I found out that the original pins were just made of plastic. I am pretty sure this is why they broke so easily. I was able to get the old material out by using the right size drill bit at a low speed. I then simply pressed the new pin in the existing hole. Enough plastic material was left to make a nice snug fit. I am sure this would be much more difficult if the pins were metal.
