polk audio subwoofer
willy88
willy88 Posts: 2
edited September 2010 in Troubleshooting
Hi i have lost my power cable to my polkaudio sub (psw350) and live in Australia and want to buy the correct one for its use, was wanting to know if a 230v~ 50hz cord is the correct one to buy?
Any help would be great.
Post edited by willy88 on
  • megasat16
    megasat16 Posts: 3,521
    willy88 wrote: »
    Most households power cords are rated to 250V and they works everywhere with 50Hz/60Hz. Just get yourself a good power cord with minimum of 14 gauge (or 12 gauge) with the correct connector for your sub on one end and the Australian standard 3 prongs plug to plug into AC mains.
    I think almost any type of normal computer power cords work fine for the polks subs but just make sure you get a good 14 gauge ones.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
