Phono Preamps.
STUFFMD
STUFFMD Posts: 381
edited July 2003 in Troubleshooting
I recently hooked up my tunntable to my reciever. I had to turn the volume almost to refrence levels to get adequate sound, and the sound I was getting was pretty flat and lifeless, I was using Pink Floyd DSOTM Original Master for a refrence disc. Would my setup be helped by a Phono preamp???? or is maybe somthing possibly wrong with my setup, although I know there's not much to that.
The cartridge is MMC.
If the preamp is the answer can someone recommend a good unit that is reasonably priced?????
Thanks, Stuff
Your system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube
Post edited by STUFFMD on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited June 2003
    MMC?
    Is it MM or MC?
    Does the Onkyo have a phono stage built in (phono input)?
  • STUFFMD
    STUFFMD Posts: 381
    edited June 2003
    M M C
    I think it stands for Moving Magnetic Coil.
    Stuff
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    PS2/Gamecube
  • STUFFMD
    STUFFMD Posts: 381
    edited June 2003
    Yes on the Phone input.
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    PS2/Gamecube
  • STUFFMD
    STUFFMD Posts: 381
    edited June 2003
    Hey Russman,
    Just looked it up..B&O calls it the Moving Micro Cross...according to what I was reading just about everything moves on the cartridge.
    Stuff
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    PS2/Gamecube
  • danger boy
    danger boy Posts: 15,722
    edited June 2003
    Stuff,
    A few years ago I ventured down this same exact path with I think the same B&O turntable. It might even my old one. :p Did you get it on ebay about a year to year and half ago?
    Anyway, I had a B&O turntable I wanted to hook up to my receiver. I bought a cheap-o preamp and hooked it up. I did get volume out of it.. but it had a noticeable hum in it.. that i could never get rid of completely. I thought maybe it just needed better gounding.. no go. So i fiddled with it for a couple months.. but still no solution.
    I'm interested to hear more about your findings on this.
    B&O gear is very beautiful to look at isn't it?
    Al
    PolkFest 2012, who's going>?
  • STUFFMD
    STUFFMD Posts: 381
    edited June 2003
    Yeah Al, I love the look of B&O, actually there is a guy on E-Bay selling a whole set for $200. I am definately giving it some thought. As far as ownership, I am the original owner, purchased back in the 80's, just bringing it out of mothballs.
    It's funny it always worked well with my old MCS 45 watt integrated.
    Stuff
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    PS2/Gamecube
  • Tour2ma
    Tour2ma Posts: 10,177
    edited July 2003
    Stuff,
    Never heard of MMC, but given what you describe it would seem to be a low output cartridge. Did your old Receiver have a MC input you used? Many old ones had phono stages for both MM and MC cart's. If a receiver has only one phono in, you can bet it's an MM.
    As for inexpensive phono pre's, I'm partial to Audio Alchemy's Vac-in-the-Box. AA is out of business, but they still pop up on ebay and go in the $100 to $150 range.
    For inexpensive new, look at the Sumiko on Audio Advisor's web site. I suspect they bought the AA design.... anyway the features and spec's seem very similar.
    More later,
    Tour...
    Vox Copuli
  • Frank Z
    Frank Z Posts: 5,860
    edited July 2003
    I'm using a MusicHall PhonoStage. Cost approx. $90 and works great!
