LSi help
JasonMKane
JasonMKane Posts: 4
edited August 2010 in Troubleshooting
Tweeters on both LSi-15 speakers did not work. Swapped tweeter from tower speakers to center channel and confirmed that it is not an issue with either tweeter as they work when connected to the center channel. Any thoughts around likely issues I am running into? Any potential solutions that I could try at home? Not interested in packaging and shipping to West Coast to have serviced. Any help is appreciated.
Post edited by JasonMKane on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited August 2010
    Check the jumpers on the binding posts of your speakers. Maybe they're not making contact or maybe they're not there at all :eek:
    Btw, welcome to CP!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • grimmace19
    grimmace19 Posts: 1,429
    edited August 2010
    ^ Jumpers came to my mind too. Did you just get them used? If so, I wouldn't be surprised if the jumpers aren't there.
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2010
    +1 to the above. The chance that both crossovers are shot seems slim, and since both tweeters were proven to work I'd say the jumpers are not in place. There should be a metal (brass) jumper that goes between the upper and lower binding posts on the back of the speakers. If that is not present, you will get only upper or lower frequencies. You could try moving the speaker connections from the lower to the upper posts to rule out a binding post issue.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • JasonMKane
    JasonMKane Posts: 4
    edited August 2010
    I have owned the speakers since they were new. Brass jumper is present for both. Followed tcrossma's suggestions to switch between upper and lower posts. Midrange drivers work fine. Still nothing out of the tweeters...
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited August 2010
    Did they ever work? Your original post made it sound like you received them in this condition. If they once worked, did something occur that you left out of your post?
    BTW, welcome to Club Polk! :)
  • JasonMKane
    JasonMKane Posts: 4
    edited August 2010
    Yes they did. I bought the speakers new and they worked. All tweeters and midrange drivers work for rear and center channel today. I've had them offline for two years now trying to fix them. Can't recall if they went dark after any particular event. Its not a speaker problem. Any other thoughts? Thank you everyone.
    F1nut Posts: 51,766
    edited August 2010
    Open them up and take a look at the resistors. There is one in the high frequency circuit that is prone to cooking.
  • JasonMKane
    JasonMKane Posts: 4
    edited August 2010
    Awesome. Now I'm in over my head. What does a "cooked" resistor look like? Any thoughts on why it might have cooked? Is that a function of running speakers too high for too long?
    F1nut Posts: 51,766
    edited August 2010
    The original resistors are the block type, which will be white/off white. Depending on how badly they have cooked they may be black/burnt looking or just slightly discolored.
    The original resistors are rated at 5 watts, which in some cases doesn't seem to be a high enough value. I would replace them with a higher watt value.
    tonyb Posts: 33,072
    edited August 2010
    Yes and no...running them too high for too long from a receiver ? Yeah,could be. Maybe alittle background sport on what gear you were driving them with and what your idea is of too loud would help. Sorry to hear of your problems but without some background, it's kinda hard to tell what happened.
