Monitor 70 Frequency
Log1x
Log1x Posts: 71
edited August 2010 in Troubleshooting
This is somewhat hard/awkward to explain...so here I go:
I usually have my Monitor 70's set to Large (Full Band) on my Onkyo for 2-channel music. Well, I turned on a hip-hop song (Drake - Miss Me) and the song happens to have a constant bass line of <29Hz and the Monitor 70's themselves are supposed to cut off. Well, what's odd, is all 4 "woofers" on the Monitor 70's fluctuate to the song corresponding to that bass line even though they are not producing any sound. I don't know how to really describe this, and I might have to make a video, but I was curious if it HURTS the speaker?
Like...the woofers are not moving to the beat of the song. Instead they fluctuate (even at VERY low volumes!) -- the woofers just move in and out, at a very steady motion and all in complete synchronization - and at the same time, it produces all the other sounds (mids/lows) of the song perfectly.
Why I'm asking this, is it's the first song I've seen them do this on. And if I change my crossover on the receiver to 40Hz it goes away...and it almost seems as if, since the woofers are swaying in and out on the song, the other "bass-lines" and what not are putting pressure on top of the swaying...almost as if it could be doing this swaying motion, and if another bass-line were to hit at high volume, it'd put pressure on the voice-coil itself and bend it into the cone..I don't know if that's even possible. But it's what it "appears" to possibly be able to do if I were to "let them loose" on the song.
If this happens to hurt the speakers, I guess I'm going to have to keep them at 40-60Hz at all times (even during 2-channel audio). I'd hate to have a random playlist going and have a song like this start blaring out. :eek:
I hope I didn't butcher my explanation too much.
Brandon
Music [2.2]
Speakers: polkaudio RTi12
Future Speakers: DIY Fusion-15 Sentinel's
Subwoofer: DIY Dual LAB15's
Subwoofer Amp: Behringer iNUKE NU6000DSP
Preamp: Emotiva XSP-1
Amp: Emotiva XPA-2
CD Player: Emotiva EMC-3
DAC: Emotiva XDA-2 Gen2
Turntable: Denon DP300F w/ Ortofon 2M Red
Tuner: Rotel RT-1080
Power: Monster HTS 5100 MKII
Amp Power: CyberPower CPS-1220RMS
Interconnects: Emotiva USS [4], XLR [6], X RCA [4], MUSB [1], X IEC [4]
Post edited by Log1x on
    edited August 2010
    Monitor overall frequency range is 30Hz-25kHz...so even though not much 'hearable' sound comes out of the M-70s at 30 or below..that does not mean that they're not trying to reproduce those frequencies--might be why the drivers seem to move but you can't hear anything. I wouldn't worry about it. The fact that they stop moving when you cut them off at 40 seems to corroborate the above.
    You can't hurt them by allowing them to run as LARGE or full range...only by clipping your amp. Which doesn't sound like what you describe.
    Don't worry, enjoy the tunes!
    cnh
  • Log1x
    Log1x Posts: 71
    edited August 2010
    cnh wrote: »
    Monitor overall frequency range is 30Hz-25kHz...so even though not much 'hearable' sound comes out of the M-70s at 30 or below..that does not mean that they're not trying to reproduce tho se frequencies--might be why the drivers seem to move but you can't hear anything. I wouldn't worry about it. The fact that they stop moving when you cut them off at 40 seems to corroborate the above.
    cnh
    Sounds good.
    I was just a little freaked out on how they all move in synchronization to a frequency that is supposed to be cut off. :p
    Thank you! :)
    Music [2.2]
    Amp: Emotiva XPA-2
    tonyb Posts: 33,068
    edited August 2010
    I would have the sub pick up that low end anyway. Might just be me,but having a speaker try to output something it physically can't do is putting undue stress on it, not good in my book. I would cross it over at 40,maybe 45,and let the sub do the dirty work.
  • Log1x
    Log1x Posts: 71
    edited August 2010
    tonyb wrote: »
    Yeah. I'll probably just do that. I'm just fond of the sound the Monitor 70's can produce without a subwoofer.
    I do set it at 40Hz when watching movies though. I just had it at Full Range for 2-channel. :)
    Brandon
    Music [2.2]
    Amp: Emotiva XPA-2
