what is the difference I am confused
jeepsr4diggin
what is the difference between a 2 channel amp that says 250 - 300 watt program and a amp that says 300 watt x 2. both are 8 ohms!
Post edited by jeepsr4diggin on
I do not understand the first listing. The amp lists spec as 250-300 watt program? What 2 amps are you comparing?Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Nothing really. Just marketing.
If an amp is rated at 250 wpc into 8 ohms then that is what it is. I know Sunfire called an amp a 300~2 or something like that. It was 300 wpc into 8 ohm and it drove two channels.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
MOST PA amps used to be listed as peak and program(RMS). That's the only bell going off right now.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
IIRC, the "program" rating is more akin to a peak power rating, not continuous power. Today's equipment is rated using FTC specifications which means that the power ratings must state a bandwidth (such as 20Hz to 20KHz), distortion rating and continuous power within the these two parameters.
Here is a good article from Polk that outlines what I am referring to:
http://www.polkaudio.com/education/article.php?id=4RT2000i - Front
CS1000p - Center
F/Xi-A6 - Surround
DSW PRO-600 - Sub
Pioneer VSX-94TXH
Panasonic TC-P54G10
