i-sonic audio quits working
mndavepk
I purchased my i-sonic from Amazon a couple of weeks ago and about a week later the audio stopped working.
Specifically, the i-sonic will be working fine (Aux input and radio) and all of the sudden the audio will stop working, almost like I hit mute. It remains responsive to all remote commands, just no sound is produced.
Shutting off and turning the i-sonic back on doesn't fix the problem. If I unplug the i-sonic and plug it back in, the problem is corrected and it works fine (feels like a hard reboot!)
This issue happened over the weekend again and the i-sonic wasn't even turned on. When I turned it on, the audio was dead, I rebooted it (unplugged and plugged back in) and now it is working again.
Firmware is 1.5.
Thanks!
Firmware is 1.5.
Thanks!
Post edited by mndavepk on
Hello,
I'm sorry you're having a problem. It would be best to contact Polk's Customer Service at 1-800-377-7655 and they can be of help.
Regards, Ken -
Firmware is 1.5.
I bought mine over a year ago, and it has the same issue. I rarely use it anymore. All in all, a disappointing product.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Hello BlueFox,
I know Polk can help with that, use the phone number above and extension 208. That's Kim Jasper, let him know you're a CP member and he'll take care of you.
Cheers, Ken -
Kenneth Swauger wrote: »Hello,
Regards, Ken
Thank you. I will call tomorrow. -
I called the Polk customer service number. They told me to return my i-sonic to Amazon (where I purchased it). Amazon took it back and sent me another one.
Well the new one has the exact same problem as the old one. The audio stops working after a while and I have to power cycle the unit.
How can I get this resolved? The customer service number didn't seem to know anything about this problem, but I'm guessing it is pretty common in some units. Seems like a software (firmware issue), not hardware.
