Networking Question
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited July 2010 in The Clubhouse
Me and some friends from class are studying networking. We are stuck on something. Does DNS come before or after DHCP and how do the interact with each other?
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • Amherst
    Amherst Posts: 695
    edited June 2010
    Obtaining an address thru DHCP comes first. DHCP will then point to the DNS box.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • bigaudiofanatic
    edited June 2010
    Thank you
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Amherst
    Amherst Posts: 695
    edited June 2010
    Keep in mind they are really separate entities. Once an address is established on a particular subnet, for data transmission on that subnet, dns enables name resolution to communicate with a particular IP. Whether it be an inside or outside IP.
  • bigaudiofanatic
    edited June 2010
    Amherst wrote: »
    We are not there yet but thank you, wil keep that in mind.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • PhantomOG
    PhantomOG Posts: 2,409
    edited June 2010
    Speaking of networking, everyone be sure to back up your router settings if you can. Yesterday we had thunderstorms and brief blackouts that somehow managed to hose my wireless router settings (DD-WRT). So I had to spend a couple hours last night re-setting everything up (mac filter lists, static IP's, etc). What a pain in the... at least now I have my router settings backed up and saved to several places in case it ever happens again.
  • Amherst
    Amherst Posts: 695
    edited June 2010
    Glad to help.
    Are you studying through Cisco's world or Big Blue's?
  • bigaudiofanatic
    edited June 2010
    Cisco Academy
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • WilliamM2
    WilliamM2 Posts: 4,773
    edited June 2010
    PhantomOG wrote: »
    I had something even worse happen. Apparently my wireless router re-set itself to defaults, I have no idea when this happened, but apparenty I have been running an unsecured wireless connection. Good way for the nieghbors to get free internet!
  • KrazyMofo24
    KrazyMofo24 Posts: 1,210
    edited June 2010
    DHCP will provide the DNS server's address along with the ip address, and gateway. Once the PC tries to open a webpage via a URL(www.polkaudio.com) the router will get the IP address from the DNS server, and the PC will store the DNS entry in it's local table.
    Setup:
    2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
    PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
  • Amherst
    Amherst Posts: 695
    edited June 2010
    You're close...some of your details are missing and incorrect.
    First the router is not involved at all, it simply handles the ip as any other communication. The PC communicates directly with the DNS server. The DNS server communicates directly to outside DNS servers for outside addresses. Inside addresses are handled by an inside DNS server, usually, but not necessarily the same server.
    DNS then reports back to PC with requested address if known.
    Big Audio good luck with your training, just finished up mine and now preparing for cert.
  • quadzilla
    quadzilla Posts: 1,543
    edited June 2010
    Amherst wins the prize, but what no one mentioned is that DHCP will only hand out the parameters it's been told to. DHCP doesn't have to give out DNS, or even a gateway. It can be configured to hand out just an IP and nothing else. Most clients can also over ride things like DNS settings. For some real fun, either read the man page for dhcpd or look at all the settings available in the MS DHCP server.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: Aural Thrills
    Digital: Pioneer DV-79ai
    Pre: Conrad Johnson ET3 SE
    Amp: Conrad Johnson Evolution 2000
  • Amherst
    Amherst Posts: 695
    edited June 2010
    Thanks, used an extremely simplified version of the process. Didn't want to mention missing settings. The big lesson is how important the DNS process is to the whole big picture.
    Lets not get into throwing 98 and NT boxes into the mix. Now that's fun!
  • bruss
    bruss Posts: 1,039
    edited June 2010
    Amherst wrote: »
    my router is totally involved as thats where my DHCP is handled and DNS is assingned. After that it is as you state, just a packet routed to that DNS ip address.
    ip dhcp pool 0
    network 10.10.10.0 255.255.255.0
    domain-name xxxxxxx.homeunix.net
    default-router 10.10.10.1
    dns-server xx.****.201.148
  • Amherst
    Amherst Posts: 695
    edited June 2010
    Don't mistake that setting in the router as being part of the DNS process or service. Requests are handled as stated.
    The router when set to handle DHCP will by necessity (most cases) need to point to DNS.
  • KrazyMofo24
    edited June 2010
    Amherst wrote: »
    You're right I mean that the router will forward the packets...I should have phrased it better. The PC itself does store dns entries so it doesn't always have to query the DNS server if it's already been there once.
    Most home networks will go to the ISP's DNS server which is tiered, and of course the inside ones for the rest.
    Bruss that's showing the settings for DHCP and what addresses (IP, Gateway, DNS) to provide to the client.
    Setup:
  • Amherst
    Amherst Posts: 695
    edited June 2010
    ^^^Necessary to keep from soaking the bandwidth.^^^
    Is the OP listening...getting his study on? HeHe.
  • bruss
    bruss Posts: 1,039
    edited June 2010
    Amherst wrote: »
    Yeah it is absolutley not doing any DNS lookups just assinging the dns I wish to use.
    Yea. just what i want to hand out for pool0. I have a different pool with a different subnet for my wireless clients.
  • potee
    potee Posts: 610
    edited July 2010
    Ok guys I use an ethernet cable to my desk top and go wirelessly to the laptop and the PS 3. Ibought a DAP-1522 to use as a bridge to my Viera V10 tv. I've tried to make it work without any luck. It says network is ok but Viera Cast wants a DNS. I tried the one thats on the router page no luck. I'm away from home right now but will be home in 8-10 days. Hopefully you will tell me things to try by then. Thanks for any suggestions.
    Paul
  • bigaudiofanatic
    edited July 2010
    Can anyone explain this to us and how we are suppose to be reading it? We have been looking at it for two days and not sure which way to look at it and how it is being explained.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Amherst
    Amherst Posts: 695
    edited July 2010
    Header chart.
    The blocks show the amount of bits used for each section (termed field) of the header.
    Source=16bits
    Destination=16bits
    Sequence=32bits
    ect.
  • bigaudiofanatic
    edited July 2010
    WOW....thanks we all stupid.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Amherst
    Amherst Posts: 695
    edited July 2010
    Never stupid.
    Hey BAF, I'll have to dig up some of my goodies for study if you like and send a copy your way. Some good stuff that helps with sorting out the Cisco way.
    Do you have a copy of Wire Shark to watch this stuff in action?
  • bigaudiofanatic
    edited July 2010
    Ya we are using wire shark and we have been getting into it little at a time. We appreciate any help.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • KrazyMofo24
    edited July 2010
    CBT nuggets are good too. Check out techexams.net that's a good forum.
    Setup:
  • bigaudiofanatic
    edited July 2010
    Ok we are on chapter 6 and completely lost. Considering the teacher did not explain what we asked him to we are in the dark.
    One of the first questions for our lab for understanding is.
    Which IP addresses are network addresses?
    a.64.104.3.7/28
    b.192.168.12.64/26
    c.192.135.12.191/26
    d.198.18.12.16/24
    e.209.165.200.254/27
    f.220.12.12.33/27
    What makes them different how can you see what is an networking address?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • concealer404
    concealer404 Posts: 7,440
    edited July 2010
    What kind of network? Private?
    If so, answer B is within the blocks set for private network.
  • bigaudiofanatic
    edited July 2010
    Networking address thats what is is asking.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • Zeros
    Zeros Posts: 940
    edited July 2010
    a.64.104.3.7/28
    b.192.168.12.64/26
    c.192.135.12.191/26
    d.198.18.12.16/24
    f.220.12.12.33/27
    Try this, it might help:
    http://en.wikipedia.org/wiki/Classless_Inter-Domain_Routing
  • John30_30
    John30_30 Posts: 1,024
    edited July 2010
    That's the header of a TCP packet, as it mentions. The pertinent parts are Source & Destination Ports-obvious enough; Sequence # is which packet # it is of thousands or millions, Acknowledgment is the TCP handshake, UDP won't have that; checksum is to make sure the packet is original, data is data- the others are not so relevant. Sometimes Window size is used to set non-babygiant MTU frames.
    Edit- didn't see Amherst's reply already explaining it.
    a.64.104.3.7/28
    b.192.168.12.64/26
    c.192.135.12.191/26
    d.198.18.12.16/24
    f.220.12.12.33/27
    the /28 or /26 etc. at the end is how it is subnetted. This is way more involved than a simple answer because you have to do the math to determine how big each subnet is, and therefore where each subnet begins and ends numerically. The 1st and last #'s are network and broadcast, so they are out.
    You pretty much have to work them out on paper, but I can tell you there are some that show up visually as being network #'s or broadcasts rather than addresses.
    And we're only talking about the 4th octet. So just visually, b has 64 as its 4th and that's usually a network #. So it's out. c has 191 and that's often a broadcast #, so it's out (usually). d is out- that one's easy because it's 24 bits, 16 subnets of 14, and 256 divided by 16 is 16- so it's a network # also.
    Wait- I was wrong on d. It's good. It has 254 subnet addresses. If it was /28 it would be invalid.
    Sheesh.
  • bruss
    bruss Posts: 1,039
    edited July 2010
    John30_30 wrote: »
    Sheesh.
    Yeah I read this as which are Networks. Not Hosts or broadcasts. Been a while since i had to subnet. let me see how wrong i can get this.
    a.64.104.3.7/28 Network is 64.104.3.0/255.255.255.240
    b.192.168.12.64/26 Network is 192.168.12.64/255.255.255.192
    c.192.135.12.191/26 Network is 192.135.12.128/255.255.255.192
    d.198.18.12.16/24 Network is 192.18.12.0/255.255.255.0
    e.209.165.200.254/27 Network is 209.165.200.224/255.255.255.224
    f.220.12.12.33/27 Network is 220.12.12.32/255.255.255.224
    Your answer is B 192.168.12.64 is a network address not a host or broadcast.
    I may be way off.. lol Im sure i will be set straight in a min
