My new Surround Bar 3000 IHT Doesn't Work
loviemac
loviemac Posts: 1
edited July 2010 in Troubleshooting
My husband just purchased the SurroundBar 3000 IHT & it is not working. I feel like I have tried everything to fix it but it's not working... at all.
We have a Sony Bravia TV and a cable/DVR box that it is connected to. I have tried changing the audio settings on both of the devices... no change.
I don't understand some of the things that are posted... guess I don't know the language. I could certainly use some help! Please!
Post edited by loviemac on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2010
    How do you have things hooked up at the moment that's not working for ya?
    Could just be something minor/overlooked and easily resolved.
    Btw, welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • shawn474
    shawn474 Posts: 3,052
    edited June 2010
    When I demoed one of these units, we had the optical cable plugged right into the television. I didn't think it would work being hooked up to the cable box.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • rags
    rags Posts: 5
    edited July 2010
    I'm having the same problem, I think. The Soundbar 3000 is not playing audio from cable (cable box - HDMI to TV - optical audio to Soundbar). Ironically, sound works from the DVD player (also hooked up via HDMI to the TV), but the Soundbar is not processing the audio signal from the TV. Any ideas?
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2010
    Same here and I've asked homebase about this as well. Stay tuned Rags & Loviemac.
  • rags
    rags Posts: 5
    edited July 2010
    Thanks. I need to return it to Crutchfield soon (while I still can), but I'll hold off for a day or two to see if you come up with something from Polk. Much appreciated.
  • dubradio
    dubradio Posts: 181
    edited July 2010
    To all,
    The Surround Bar 3000 must be given 2 channel (stereo) signal via PCM signal to operate.
    What does this mean?
    A: Some televisions/cable/sat boxes only carry Dolby digital signal (5.1) signal out via HDMI or Digital Optical. To properly integrate with the Surround Bar 3000 you would need to stop by your local electronics retailer and pick up a Stereo RCA to 1/8" cable (http://www.radioshack.com/product/index.jsp?productId=3909621).
    This would allow you to make a direct connection from the cable/sat boxes' analog output directly to source 2 or 3 on the back of the Surround Bar.
    If you have any further concerns or questions give us a call and we can help. 1-800-377-7655 Mon-Fri 9am-5:30pm EST.
  • Bobsama
    Bobsama Posts: 526
    edited July 2010
    Make sure the TV or cable box knows that it can do optical-out. I noted that as a problem before where my TV's speakers had to be set to "external" and the volume turned up to 100% in order to get normal audio to an AVR. I also had to specifically enable the Toslink-Out port; it was lit but it wasn't sending signal.
    As I said, I've had that problem before and it's usually buried in menus to enable something that should be on from Day 1. I don't know about the cable-box though; I've heard from someone trustworthy in the industry that many cable/satellite providers disable non-secure outputs on the cable-box, in an attempt (however vain) to foil piracy.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • rags
    rags Posts: 5
    edited July 2010
    Kyle,
    Thanks. That worked. I now have audio. I just hate that it's an analog signal. I have HDMI from the cable box, but then have to 'dumb it down' to a mini jack. Kinda stinks.
