Polk mid range driver "freeze"
Big Dan R
What is the cause and solution to why Polk mid range drivers "freeze" ? They no longer move as much but still produce sound? The lower freq's are diminished. Interconnects, driver connects seem ok. Maybe crossovers???
Thanks,
Dan
Thanks,
Dan
What speaker model are you referring to? One in specific?
I know on the SDA/Monitor/RTA series, sometimes in shipping (if handled very rough, the magnet on the driver can actually shift, and 'lock' the voicecoil in place. The driver will still produce *some* sound, but no movement in the cone whatsoever.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Gentle pressure should be applied at the cones outer edge as equally as you can around its perimeter with thumb and fingers spread wide.
With the system shut down, if you press gently on the mid/woofs do they move freely or seem to be dragging? If they seem to drag it could be the magnet as Russ suggested or the voice coil.More later,
Tour...
Vox Copuli
These drivers (3 of them which I think are the MW 6503's) are in the same cabinet of a pair of the original SRS model. I have a chance to buy this pair in "good condition" from someone 60 miles away for hopefully might be a damn good price. I will learn more when I go to audition them but wanted some up front advice.
BDR -
Ah... the SDA's in your 'hood you were told of?
A couple of bad drivers should make an excellent bargaining point.
Good luck and keep us posted.More later,
Tour...
Vox Copuli
