Polarity issues
Bill9306
Hello,
I just go a pair of RTI A9 speakers and when I ran the auto setup on my yamaha reciever, it stated that they were out of phase. I triple checked the wiring for incorrect polarity and found no mistake. I ran the test again and it still stated it was out of phase. I switched the wires and hooked positive to negative and negative to positive. I ran the test again and the reciever stated the speakers were hooked up correctly. So, to make totally sure I took my surround speakers and hooked them up to the front and the Rti a9s to the back and the reciever stated the surrounds that I hooked up to the front were ok and the RTI A9s i hooked in the surround position were showing out of phase. What I am asking is, can the speakers be wired incorrectly in the box and if it is, can the speakers run perfectly fine and like it is supposed to if I keep them hooked up according to what the reciever states I should?
2 RTI A9 Cherry
1CSI A6 Cherry
2 RTI A1 for Surrounds Cherry
Yamaha RXV 663 Receiver
Emovita XPA 3 Amp
1CSI A6 Cherry
Emovita XPA 3 Amp
Post edited by Bill9306 on
Go with the right polarity. Don't listen to your receiver unless the appropriate polarity is out of phase.Speaker: LSi 15
Pre/Pro: Pioneer VSX-9040
Amp: Emotiva XPA-2
Sub: Seaton Submersive HP
TV: Samsung PN50B550
DAC: soon-to-be EE Minimax Dac Plus -
It's possible there was a wiring error that slipped past QC.Do the speakers sound better when the one is connected with reversed polarity?If they are out of phase stereo imaging will be indistinct and bass response will be noticably reduced.What I am asking is, can the speakers be wired incorrectly in the box and if it is, can the speakers run perfectly fine and like it is supposed to if I keep them hooked up according to what the reciever states I should? -
I would say 'pop' test them with a 9v BUT DC IS BAD FOR TWEETERS! Bad wiring COULD have slipped past QC(possible, not likely). FTGV nailed it though-if they're actually out of phase-low end will SUFFER and your stereo separation will be very narrow. Change polarity on ONE at a time until they sound right/better then re-run your setup and see what it says.Onkyo TX-SR705 AVR
Onkyo M-501-Given to my father.
Onkyo DX-C730 CD Changer
Onkyo DV-BD507 Blu Ray player
Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
Polk Monitor 12's with RDO's and XO's
Polk CS300 Center
Polk Monitor Series 4 rears
EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek: -
My Pioneer does the same thing occasionally with one of my surrounds.. that little mic isnt perfect.. if you are sure you have it hooked up right i'd leave it
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
I talked with polk and they stated because there is a "second order" crossover network in the speaker cabinet, it can "confuse" some reciever microphone tests. I took you all's advice and played with the set up. It ended up sounding great with it hooked up the correct way even though the reciever says it is "out of phase". Thanks for helping me out.2 RTI A9 Cherry
1CSI A6 Cherry
Emovita XPA 3 Amp -
Find the the same problem with the RTI A9 speakers, check the polarity with 1.2 v AAA battery the subs move inwards an not outwards as with normal speakers tested. I had previously a set of Polk RTI A7 and thy respond positive to the test, any suggestions
