TV Acting Strange
xsmi
xsmi Posts: 1,798
edited June 2010 in Troubleshooting
My 42" Sansui Plasma TV loses the picture after being on for about an hour. I can tap the back right side of the TV and it comes back on. Any ideas?
Yeah I know Sansui but it is all I got.
2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Post edited by xsmi on
  • ViperZ
    ViperZ Posts: 2,046
    edited June 2010
    xsmi wrote: »
    Sounds like bad connection somewhere if you can fix it by tapping. The problem is you really need to know what you're doing when you're opening one of these flat panel TVs - the voltages inside are high enough to kill you.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    tonyb Posts: 32,997
    edited June 2010
    Most likely the power supply,seems to be the number one problem with plasma's. Call a tech,get a rough estimate, for what a new one costs, you maybe better off going that route.
  • xsmi
    xsmi Posts: 1,798
    edited June 2010
    Thanks guy. I will be taking it to the shop tomorrow.
