Windows Vista log on problem, need help
  • mmadden28
    mmadden28 Posts: 4,283
    edited July 2010
    Can you locate the .exe file that is running? If so you can submit that to a site (there are several) that will scan it--There are several ways to determine the executable, the most basic way is to launch Task Manager and look for the Adobe Updater task that's running--Then right click on it and select Properties, that will tell you where the file is located.
    I have to run right now, I'll see if I can find any of those sites that you can submit the file to later tonight....
    ____________________
    Pool: Atrium 60's/45's
  • mmadden28
    edited July 2010
    Here ya go--I believe this is the same site I used to use:
    http://www.virustotal.com
    You upload a suspiscious file to them via web based interface, and it will be scanned real-time by about 40 different AV programs for any malware, etc.
  • seeclear
    seeclear Posts: 1,244
    edited September 2012
    :smile:Sorry to bump an old thread, but I had to thank kawizx9r for his suggestion in post 2. I just had this happen with my son's laptop running XP, but his solution worked just great!!! Thanks, Thanks, Thanks!
    Great people on this forum!:cheesygrin:
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • cwuirmm
    cwuirmm Posts: 1
    edited September 2016
    You can simply solve the problem by resetting the admin password or creating a new admin account. Here is a step by step guide on how to do this: http://www.uukeys.com/reset-windows-vista-password.html
    billbillw Posts: 7,477
    Geeze. I just spent 5 minutes reading a post from 2010! Dammit. I flagged the spammer.
    msg Posts: 10,452
    haha, well it is a good password reset tool to use that Kawi mentioned.
  • uuuuuuuh Windows 10 anyone??? ;)
  • I'm thinking about going from DOS 3.0 to DOS 3.3 on my 80286 PC so that I can install a 32.8 meg hard drive. Is it worth it ?
    Also, I'm having trouble understanding the difference between expanded memory and extended memory.
    Can anybody help me ? o:)
  • Nightfall
    Nightfall Posts: 10,084
    Jump for the 486 so you can run Doom, they invented this crazy thing called online multiplayer.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • I had a similar problem and asked for help with Google,then i got it,thank you guys,i got a lot of help from here.
    F1nut Posts: 51,698
    You still need help.
  • FestYboy
    FestYboy Posts: 3,861
    It's Necro thread revival Friday!!!
  • I got it: https://www.winpwd.com/
    I will try it on my computer tomorrow.
  • verb
    verb Posts: 10,176
    edited September 2019
    Spammer
    Did NOT hit that link this time! :)
    pitdogg2 Posts: 26,959
    verb wrote: »
    Spammer
    You thought about it lol 😂
