LSI15 Best wiring option
LitoZacky
LitoZacky Posts: 115
edited June 2010 in Troubleshooting
I would like to know how should I wire a pair of LSI15 to an Emotiva XPA-2. Should I wire them normally?
Or Bi-Wire?
Or Bi-Amp?
If I am going to biamp could I hook for instance, the left/right plugs from the amp to the LC speaker and then another left/right plugs from the AVReceiver(pioneer vsx-9040 110w per channel, capable for biamping) to the same LC speaker ?
My budget is $100 for wires.
Speaker: LSi 15
Pre/Pro: Pioneer VSX-9040
Amp: Emotiva XPA-2
Sub: Seaton Submersive HP
TV: Samsung PN50B550
DAC: soon-to-be EE Minimax Dac Plus
Post edited by LitoZacky on
  • LitoZacky
    edited June 2010
    Nvm. I have decided to not biwire but buy a quality pair of speaker cable instead.
    Speaker: LSi 15
    Amp: Emotiva XPA-2
  • fbm211
    fbm211 Posts: 1,488
    edited June 2010
    You should be ablet to get some decent cables at audiogon for that budget.Or if you want to save get some canare 4S11.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • LitoZacky
    edited June 2010
    I bought a pair of brand new "AudioQuest Type 4" speaker cable from ebay for $89 based on some recommendation from folks here. My initial decision was to buy Emotiva X-series speaker cable but it was $140 for a pair.
    I should plug the speaker wire into the lsi15 on the top 2 inputs, or the bottom 2 inputs ?
    Speaker: LSi 15
    Amp: Emotiva XPA-2
  • PSOVLSK
    PSOVLSK Posts: 5,237
    edited June 2010
    You'll be happy with the AQ4's.
    Tor or bottom, doesn't matter.
  • LitoZacky
    edited June 2010
    Thanks for reassuring me. I am coming from a pair of Infinity P362. Will the LSI15 blow me away ?
    Speaker: LSi 15
    Amp: Emotiva XPA-2
  • Jetmaker737
    Jetmaker737 Posts: 1,056
    edited June 2010
    PSOVLSK wrote: »
    Top or bottom, doesn't matter.
    Bottom!!
    SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|Nakamichi RX-202 Cassette
    tonyb Posts: 33,020
    edited June 2010
    I normally do bottom,and make sure the jumpers are in place.
  • LitoZacky
    edited June 2010
    Bottom it is. Thanks
    Speaker: LSi 15
    Amp: Emotiva XPA-2
