Bad tweeter or problem with crossover w/RTA 11t
altrace
altrace Posts: 2
edited June 2010 in Troubleshooting
I have a pair of "new to me" RTA 11t's and it appeared that one of the tweeters was defective. No sound and I assumed that it needed to be replaced. Damaged the tweeter when removing and so I replaced both tweeters with JBL silver titanium tweeters and lo and behold I still had the same problem. I'm wondering if the problem is in the crossover or might it be something simple that I'm overlooking? Any suggestions would be helpful.
Post edited by altrace on
  • ben62670
    ben62670 Posts: 15,969
    edited June 2010
    First step is to take the known good tweeter and install it in the "bad" speaker.
    Welcome to Club Polk.
    Ben
  • altrace
    altrace Posts: 2
    edited June 2010
    Both of the JBL tweeters were working before I installed them.
    F1nut Posts: 50,816
    edited June 2010
    You have a bad polyswitch, it's located on the crossover board. You can remove it and replace it with a .5 ohm resistor or purchase a new polyswitch.
    Get those JBL tweeters out of the Polks.
