CSiA6 Crackling
laneman
laneman Posts: 4
edited June 2010 in Troubleshooting
Today I noticed my center channel is crackling on the voice tracks of any movie I put in...its not even 3 months old. Anything I can check to ensure its the actual tweeter or some other problem?
Post edited by laneman on
  • kevhed72
    kevhed72 Posts: 5,062
    edited June 2010
    Start by checking your connections on everything from the source to the speaker. If that's not it, try running different sources through the center channel to see if its the DVD player, cable box, etc. If you determine there is actually a problem with the center, Polk customer service is top notch...:)
  • BeefJerky
    BeefJerky Posts: 1,320
    edited June 2010
    In addition to those suggestions, I also suggest swapping the center speaker with either your left or right speaker. Then you can tell whether the crackling follows the speaker or the output of the receiver.
  • helipilotdoug
    helipilotdoug Posts: 1,229
    edited June 2010
    So did you get it figured out?
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
