Anthem Amp Right Channel
aiden
My Anthem MCA 20 amp right channel died yesterday!
Over the past month or so, when ever I powered down the system, I would hear a whistle come from my right front speaker! The whistle got lighter and lighter, then stop as the power left the system. Now, there is no sound at all coming from that channel. I know it's the amp, because I've switched speakers and amps to narrow it down to that amp channel.
I am not looking forward to sending it out to be repaired (time and money). Before I do, I want to ask around and get other people's opinions.
I have replaced the fuses inside ( two per channel). No luck! Is there other things I can look for? Or suggestions!
Thanks!!
Thanks!!
Post edited by aiden on
It may be one of your caps that has gone bad. where you located?____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
dpowell,
I was just in contact with Anthem service and they said the same thing (cap)!!
If I knew which one, I'd replace it myself.
I'm a long way from sunny San Diego, Cal. Louisville, Ohio 7 mi. from Canton.
I run a PRE2L also! Love it. Wish I had a Amp-2 in place of the MCA 20. Oh well one problem at a time. -
Is there a way to test the cap?
How many caps in your amp? best practices is to replace both caps in a pair when one goes bad so that they are evenly balanced. Just replaced two in an RT3000 sub amp and Polk's recommendation was that both caps be replaced. See if Anthem can tell you where to get the replacements or if you can order directly from them.
doug____________________________________________________________
dpowell,
The Pre2L is great! I have it running temp duty in the home theater while my AVR is being fixed. It sure adds a nice sound!____________________________________________________________
dpowell,
It looks like one of the caps has a loose or broken connection to the board. I'm going to try to solder it later to night. I'll let you know if it works!! By the way, there's three caps per channel, 100V 100uf. -
Interesting. Replacement caps from Polk CS ran around $13 each. Not sure what they were rated at.____________________________________________________________
I've done a little soldering to the loose cap connection and also glued the plastic top to the speaker connection to the right amp channel. the plastic was not connected to the metal screw done. I am back with sound in both channels, but still has the whistling sound (coming from the right speaker) when powering down!? All other channels are fine, just that one makes a continuing whistling sound till the power is out of the channel.
Is that the cap going or something else? -
Replace that cap for sure. Actually, as already suggested, replace the same cap in another channel too.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I think the trouble shooting section is for POLK PRODUCTS, not just every gear problem. Certainly post your gear issues, but perhaps in the electronics or 2 channel section. I've noticed a lot of random posts here.
The intent is for customers to get a dialog going if they are having issues with a POLK branded product.
Just food for thought.
Thanks for the heads up heiney9. I'll know better next post!
I'm going to replace the caps ViperZ. -
Let us know how it turns out.____________________________________________________________
