New hard drive and fresh XP install=snappy
fbm211
You all know that fresh OS install just gives you that quick snap back to your rig.Im lovin it.The 2 years of bloat is gone.
I bought a 150gig VelociRaptor on ebay a few days ago for 65 bucks and stated over last night.Now I just hope I can get my dragonage saves transfered correctly and get the expansion when the price drops to 30 bucks.
Anyone know where I can get a free dvd decoder for mediaplayer??.I cant find the activation code for WinDVD 8 I bought a few years ago.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
My wifes computer crashed a couple weeks ago so I re-installed XP from scratch. It runs a whole lot better than it has in years. Its a 10 year old compy though so its kinda weird cruising around online with IE6.
Check CNET.com and look around. Theyve got freeware versions of anything you could think of.polkaudio sound quality competitor since 2005
once you have everything installed the way you want, "ghost it" and the next time you need to reinstall it will be a lot faster;)Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
+1 for the ghost. Also get rid of IE6. lol
It is amazing how smooth things are when you start over.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
You'll be back to your laggy self in a month or 2.
It's the nature of Windows."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
IIRC, but I could be wrong, the Shark or K-lite codecs include a dvd decoder. WARNING: Backup/ghost your box before installing any codec.
Or you can try Windows Media Player Classic for free (does not require an install).
Good luck! -
fatchowmein wrote: »Or you can try Windows Media Player Classic for free (does not require an install).
Good luck!
MPC works fine.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
My wifes computer crashed a couple weeks ago so I re-installed XP from scratch. It runs a whole lot better than it has in years. Its a 10 year old compy though so its kinda weird cruising around online with IE6. ...
http://www.microsoft.com/windows/internet-explorer/support/system-requirements.aspxryanjoachim wrote: »You'll be back to your laggy self in a month or 2.
Also, using Microsoft Security Essentials with XP (or Windows 7), instead of vendor virus software, seems to help a lot:
http://www.microsoft.com/security/products/mse.aspx
Finally, my word of useless advice: don't put no **** on your computer unless you're sure you actually will use it. Downloading trial software (as well as useless frills) right, left and center seems to really do a lot of harm to performance, even when it is subsequently removed.Alea jacta est! -
Next time consider SSD. Runs circles around that raptor.Shoot the jumper.....................BALLIN.............!!!!!
Not really. We have installations at work that are 7 or 8 years old, and no slower than when new. Seems every program written these days likes to run on start up unnecessarily. Simply using msconfig will fix the lag on many computers. -
With XP, you should be able to run IE7 or IE8. They are much better IMO, and I even stopped using Firefox (after five years or so as a loyal follower) with IE7. The system requirements are quite minimal
Oh yeah I did - actually installed Chrome. It just looked kinda weird at how dated IE6 looks now.polkaudio sound quality competitor since 2005
